This document was generated from CDN thread
Created by: null on 05-12-2005 04:55:08 AM
can you tell me whether or not latency with audio fetching is generally a concern for Audium apps? Can audio fetch complete times vary by more than 1 - 2 seconds for the same audio segment in the same app?
Dan
Subject: RE: Latency concern
Replied by: Vance Vagell on 05-12-2005 04:47:27 PM
Hi Dan,
Each voice browser handles audio fetching differently, and so it is best to refer to a given voice browser's documentation and release notes for specific details. Typically, voice browsers allow for some tuning to improve audio fetching performance.
During our internal testing of various voice browsers we have not encountered a latency of more than 1-2 seconds. Generally, audio files are either hosted on a media server on the same local network as the Audium Call Services server, or are hosted on the same server (for small deployments). This eliminates most network-related sources of latency, and so the primary source would be the voice browser's configuration choices.
Vance
