cdnadmin
Community Member
This document was generated from CDN thread
Created by: Matt K. on 16-10-2008 08:13:04 PM
How do I configure # when I define an Inline DTMF Local Hotlink in CVP Studio. When I use #, it does not work and I keep getting nomach but when I use * it works fine. CVP Studio does not let me to configure it as '#' either
Matt
Subject: Re: Local Hotlink does not work with # (dtmf-#)
Replied by: Janine Graves on 16-10-2008 08:37:41 PM
  1. is preconfigured as the termchar.
So it is always stripped off by the gateway.
You will have to disable the termchar to receive # into the app
You set the vxml property named termchar to z (or anything other than a dtmf touchtone). This can be done in the root document using project properties or temporarily in any vouce element in the Settings tab.
ELM NMS Team
Thanks a lot , it is working with me.
