cdnadmin
Community Member
This document was generated from CDN thread
Created by: Steve Scott on 12-01-2010 09:56:23 AM
Hi, I am not sure if anyone else has noticed this problem or it is linked to something on my system. I have a c90 running TC2.1 and is connected to an AV2 via Serial. When dialing a call I am using dialkeypad on the module.
If I make a call to another system which has auto answer off, Disconnect that call and immediately redial the same number the call fails. If you give yourself around 30 seconds before making the seconds call it works fine. During my program there are other ways to make this fail but this seems to be the main one.
I have used Simpl debugger and watched the commands between the codec and AV2 and it takes around 30 seconds from the call disconneting before the module tells me that the codec has disconnected the call.
I have spoke to a crestron tech support engineer and he has asked me to raise this via this site.
Any help would be great
Steve
Subject: RE: Module Running Slow
Replied by: David Bruun-Lie on 12-01-2010 11:30:36 AM
Hi Steve,
are you using the module found on this site or on crestron.com or have you written your own? I have the same configuration as you have on my desktop, except that I have a Pro2 and I am able to connect and disconnect with both autoanswer on and off, manually answering and not answering etc. literaly as fast as I am able to do it on the control panel and I get the correct updated call status for both connect and disconnect. I use the latest crestron module available from this site (and that I wrote myself)
As a note, if registering feedback expressions that are too general (like registering ALL status feedback)  you may end up with the codec flooding the control system as we have seen that the Crestron Control systems have problems keeping up with the data received from the codecs - this is something that Crestron is trying to figure out.
Is the AV2 doing a lot of other stuff at the same time?
For this I assume that you are using our module:
If you hang up the call from the control panel, how long does it take from "Hang_Up_Call_1" to "Call_status_Call1_Is_Active" goes to 0 and what is going on between those two signal changes? It should be around 18 signal changes and within a time span of 0.6 seconds.
David
Replied by: Steve Scott on 12-01-2010 12:26:48 PM
Hi David
I am currently using version 1.2 of the module found on this site. I guess I should try the new version 1.3 first and see if this fixes the problem.
I am not registering any Other expressions.
The code is a very basic and is not really doing anything in the back ground, Unfortunatly I did not write all the code, a guy from crestron wrote it first and I am not fixing all the current snags.
The Call_Status_Call_1_Is_Active can vary on when it goes from 1 to 0. From disconnecting the call it can be instant one time then take upto 1 minute to report back that the call is not active.
I have also found that I have made a call to a endpoint, it connects and I get video ETC. But for some reason I am unable to disconnect, I have to leave it between 30 secs and 1 minute before the module knowns the call is connected and allows me to disconnect.
It is a really strange fault I have found and only really happens when you use the system quickly,
I will get the lateast version of the crestron module and try that first and report back later today if this has fixed the issue.
If that does not work would it be ok for me to send the code to you for you to test on your system.
Steve
Replied by: David Bruun-Lie on 12-01-2010 02:08:47 PM
ok,
test the 1.3 module as it has some significant speed improvements compared to 1.2 and may do the trick. If not, I'll have a look at your module if you send me a copy. I'll send you an email with my contact details...
David
Replied by: Steve Scott on 12-01-2010 04:32:56 PM
Hi David
Tried 1.3 and it seems to be even worse than 1.2. I have problems not only with dialing a call but mic muting and other things appear to happen also.
I have sent you an email with my program an a txt file from debugger which gives you some idea of what is happening.
Let me know your thoughts on it.
thanks
Stee
Replied by: David Bruun-Lie on 19-01-2010 01:29:45 PM
Steve,
how are you getting on? Any progress? As I responded in my email, I did not see the issues that you are describing when using my codecs and control system.
David
Replied by: Steve Scott on 17-02-2010 10:27:43 AM
Hi David
I am still experiencing the issue with the module running very slow, I have not had chance to look at this issue recently but I am going to have another go at it next week.
I will let you know what happens.
Steve
