cdnadmin
Community Member
This document was generated from CDN thread
Created by: Stephan Steiner on 01-10-2013 04:26:39 AM
Here's a getPhone response... note how all uuids use curly brackets around them and are all upper case. Except for monitoringCssName which is upper case and lacks the bracket.
Just ran into this in my testing or our custom AXL lib
-<phone uuid="{03A633D8-FB01-C160-613F-A30E46069114}"> <name>SEP110000000012</name> <description>an updated phone</description> <product>Cisco 7975</product> <model>Cisco 7975</model> <class>Phone</class> <protocol>SIP</protocol> <protocolSide>User</protocolSide> <callingSearchSpaceName
uuid="{3AAA1E94-19B3-8A53-EDD0-B42D01A2E851}">c_all</callingSearchSpaceName> <devicePoolName
uuid="{1B1B9EB6-7803-11D3-BDF0-00108302EAD1}">Default</devicePoolName> <commonDeviceConfigName/> <commonPhoneConfigName
uuid="{AC243D17-98B4-4118-8FEB-5FF2E1B781AC}">Standard Common Phone
Profile</commonPhoneConfigName> <networkLocation>Use System Default</networkLocation> <locationName
uuid="{C7E2C026-54B3-55DD-A0A2-D649501F9929}">Phantom</locationName> <mediaResourceListName
uuid="{50A85154-76A5-9B9E-5778-D60BFBFF1058}">MRGL_all_sw</mediaResourceListName> <networkHoldMohAudioSourceId>1</networkHoldMohAudioSourceId> <userHoldMohAudioSourceId>1</userHoldMohAudioSourceId> <automatedAlternateRoutingCssName uuid="{6B060A31-A952-FB93-EC47-E9151488BCC9}">c_internal</automatedAlternateRoutingCssName> <aarNeighborhoodName/> <loadInformation
special="false">SIP75.9-3-1SR2-1S</loadInformation> <vendorConfig/> <versionStamp>{1380619246-6BDAF51C-201A-4AA2-92E3-EB35FF534F72}</versionStamp> <traceFlag>false</traceFlag> <mlppDomainId/> <mlppIndicationStatus>Off</mlppIndicationStatus> <preemption>Disabled</preemption> <useTrustedRelayPoint>Default</useTrustedRelayPoint> <retryVideoCallAsAudio>true</retryVideoCallAsAudio> <securityProfileName
uuid="{5186F831-CC5B-4D35-B057-6FF607F162D4}">Cisco 7975 - Standard
SIP Non-Secure Profile</securityProfileName> <sipProfileName
uuid="{FCBC7581-4D8D-48F3-917E-00B09FB39213}">Standard SIP
Profile</sipProfileName> <cgpnTransformationCssName/> <useDevicePoolCgpnTransformCss>true</useDevicePoolCgpnTransformCss> <geoLocationName/> <geoLocationFilterName/> <sendGeoLocation>false</sendGeoLocation>-<lines>-<line uuid="{0CC9F28C-71E2-F1DF-7167-08556CF5F095}"> <index>1</index> <label>blöök</label> <asciiLabel>blubber</asciiLabel> <display>hüschgürum</display>-<dirn uuid="{851FEF20-AAB9-FA3D-0798-713589ED8AA8}"> <pattern>7306</pattern> <routePartitionName
uuid="{893DF26C-2068-DCEC-4774-E893593E8C7E}">p_phones</routePartitionName> </dirn> <ringSetting>Ring</ringSetting> <consecutiveRingSetting>Disable</consecutiveRingSetting> <ringSettingIdlePickupAlert>Ring Once</ringSettingIdlePickupAlert> <ringSettingActivePickupAlert>Beep Only</ringSettingActivePickupAlert> <displayAscii>display</displayAscii> <e164Mask>044815XXXX</e164Mask> <dialPlanWizardId/> <mwlPolicy>None</mwlPolicy> <maxNumCalls>2</maxNumCalls> <busyTrigger>1</busyTrigger>-<callInfoDisplay> <callerName>true</callerName> <callerNumber>true</callerNumber> <redirectedNumber>true</redirectedNumber> <dialedNumber>true</dialedNumber> </callInfoDisplay> <recordingProfileName/> <monitoringCssName
uuid="6b060a31-a952-fb93-ec47-e9151488bcc9">c_internal</monitoringCssName> <recordingFlag>Call Recording Disabled</recordingFlag> <audibleMwi>On</audibleMwi> <speedDial/> <partitionUsage>General</partitionUsage> <associatedEndusers/> <missedCallLogging>true</missedCallLogging> </line> </lines> <numberOfButtons>8</numberOfButtons> <phoneTemplateName
uuid="{C3838894-0929-476E-8E13-5077FE55FD1C}">Standard 7975
SIP</phoneTemplateName>-<speeddials>-<speeddial> <dirn>7300</dirn> <label>sd-test</label> <asciiLabel>sd-test-ascii</asciiLabel> <index>1</index> </speeddial>-<speeddial> <dirn>7301</dirn> <label>sd-test2</label> <asciiLabel>7301</asciiLabel> <index>2</index> </speeddial> </speeddials>-<busyLampFields>-<busyLampField> <blfDest/> <blfDirn>7303</blfDirn> <routePartition>p_internal</routePartition> <label/> <asciiLabel/>-<associatedBlfSdFeatures> <feature>Pickup</feature> </associatedBlfSdFeatures> <index>1</index> </busyLampField>-<busyLampField> <blfDest>7503</blfDest> <blfDirn/> <routePartition/> <label>blf 7305</label> <asciiLabel>blf 7305</asciiLabel> <associatedBlfSdFeatures/> <index>2</index> </busyLampField> </busyLampFields> <primaryPhoneName/> <ringSettingIdleBlfAudibleAlert>Default</ringSettingIdleBlfAudibleAlert> <ringSettingBusyBlfAudibleAlert>Default</ringSettingBusyBlfAudibleAlert> <blfDirectedCallParks/>-<addOnModules>-<addOnModule> <loadInformation
special="false">SIP75.9-3-1SR2-1S</loadInformation> <model>7914 14-Button Line Expansion Module</model> <index>1</index> </addOnModule> </addOnModules> <userLocale>German Germany</userLocale> <networkLocale>Germany</networkLocale> <idleTimeout/> <authenticationUrl/> <directoryUrl>http://myappserver/Directory</directoryUrl> <idleUrl/> <informationUrl>gugus</informationUrl> <messagesUrl/> <proxyServerUrl/> <servicesUrl/> <services/> <softkeyTemplateName
uuid="{72F64050-7AD5-4B47-9BFA-5E9AD9CD4AA9}">Standard
User</softkeyTemplateName> <loginUserId/> <defaultProfileName/> <enableExtensionMobility>true</enableExtensionMobility> <currentProfileName/> <loginTime/> <loginDuration/>-<currentConfig> <userHoldMohAudioSourceId>1</userHoldMohAudioSourceId> <phoneTemplateName
SIP</phoneTemplateName> <mlppDomainId/> <mlppIndicationStatus>Off</mlppIndicationStatus> <preemption>Disabled</preemption> <softkeyTemplateName
User</softkeyTemplateName> <ignorePresentationIndicators>false</ignorePresentationIndicators> <singleButtonBarge>Default</singleButtonBarge> <joinAcrossLines>Default</joinAcrossLines> <callInfoPrivacyStatus>On</callInfoPrivacyStatus> <dndStatus/> <dndRingSetting>Disable</dndRingSetting> <dndOption>Call Reject</dndOption> <alwaysUsePrimeLine>Default</alwaysUsePrimeLine> <alwaysUsePrimeLineForVoiceMessage>Default</alwaysUsePrimeLineForVoiceMessage> <emccCallingSearchSpaceNamexsi:nil="true" uuid="" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" /> <deviceName/> <model/> <product/> <deviceProtocol/> <class/> <addressMode/> <allowAutoConfig/> <remoteSrstOption/> <remoteSrstIp/> <remoteSrstPort/> <remoteSipSrstIp/> <remoteSipSrstPort/> <geolocationInfo/> </currentConfig> <singleButtonBarge>Default</singleButtonBarge> <joinAcrossLines>Default</joinAcrossLines> <builtInBridgeStatus>On</builtInBridgeStatus> <callInfoPrivacyStatus>On</callInfoPrivacyStatus> <hlogStatus>On</hlogStatus> <ownerUserName
uuid="a57e8ab7-a190-5e7a-db3a-db9bf1f0b158">sste</ownerUserName> <ignorePresentationIndicators>false</ignorePresentationIndicators> <packetCaptureMode>None</packetCaptureMode> <packetCaptureDuration>0</packetCaptureDuration> <subscribeCallingSearchSpaceName/> <rerouteCallingSearchSpaceName/> <allowCtiControlFlag>true</allowCtiControlFlag> <presenceGroupName
uuid="{AD243D17-98B4-4118-8FEB-5FF2E1B781AC}">Standard Presence
group</presenceGroupName> <unattendedPort>false</unattendedPort> <requireDtmfReception>false</requireDtmfReception> <rfc2833Disabled>false</rfc2833Disabled> <certificateOperation>No Pending Operation</certificateOperation> <certificateStatus>None</certificateStatus> <upgradeFinishTime/> <deviceMobilityMode>Off</deviceMobilityMode> <remoteDevice>false</remoteDevice> <dndOption>Call Reject</dndOption> <dndRingSetting>Disable</dndRingSetting> <dndStatus>false</dndStatus> <isActive>true</isActive> <isDualMode>false</isDualMode> <mobilityUserIdName/> <phoneSuite>Enabled</phoneSuite> <phoneServiceDisplay>Both</phoneServiceDisplay> <isProtected>false</isProtected> <mobileSmartClientProfileName/> <mtpRequired>false</mtpRequired> <mtpPreferedCodec>711ulaw</mtpPreferedCodec> <dialRulesName/> <sshUserId/> <digestUser/> <outboundCallRollover>No Rollover</outboundCallRollover> <hotlineDevice>false</hotlineDevice> <secureInformationUrl/> <secureDirectoryUrl/> <secureMessageUrl/> <secureServicesUrl/> <secureAuthenticationUrl/> <secureIdleUrl/> <alwaysUsePrimeLine>Default</alwaysUsePrimeLine> <alwaysUsePrimeLineForVoiceMessage>Default</alwaysUsePrimeLineForVoiceMessage> <featureControlPolicy/> <deviceTrustMode>Not Trusted</deviceTrustMode> <requireOffPremiseLocation>false</requireOffPremiseLocation> <userlocale>German Germany</userlocale> </phone>
