cdnadmin
Community Member
This document was generated from CDN thread
Created by: Michael Black on 09-01-2009 07:54:56 PM
I am working with the multi directory script from the SDK. I am trying query 2 differnt LDAP Active Directory Domains.
I am hosting the app off a win 2003 box. When i test the directory it comes back with an XML Phase 4 error or an http 500 depends on what model phone i use.
I tried to run search via a web browser using the url below:
From firefox the url i entered was: http://10.1.2.58/CiscoIPServices/multidirectory/multidirectory.asp?action=list&id=1&f=sean
when i did a view source i get the following below. I have also attached the multidirectory script.
Thank for the help
Microsoft JScript runtime error '800a01b6'
Object doesn't support this property or method
/CiscoIPServices/multidirectory/multidirector.asp, line 182
If i search and new results are returned there are no errors, but if there are results thats when i get the error above. I have attached the script
thanks
