cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 31-07-2003 09:02:29 PM
I've got a question regarding the settings that could appear more than once on the element setting pane (that have red plus sign beside them).
Whether the order of those settings at runtime depends on the order in which they were added to the setting pane during development?
Other words, if I put value for setting_1 is "Tom", value for next setting_1 is "John", and value for the last setting_1 is "Mike", at runtime in the array setting_1 Tom will always be the first, and Mike will always be the last one in the list? Or they will be put into array at random order, so Mike could sometimes come first?
Thanks.
Tatiana
Subject: RE: Multiple setting order
Replied by: null on 31-07-2003 11:03:50 PM
Hi Tatiana,
The order you enter a repeatable setting does not matter. I am assuming you are talking about the Form element voice keyword setting? If so, the inline grammar will contain all voice keywords and the ASR engine does not care in which order they appear.
If you are talking about getting those settings in a dynamic configuration, we cannot guarantee the order they will appear in.
Replied by: null on 01-08-2003 06:54:10 PM
Hi Tatiana,
In addition to what Elam mentioned, if you are building your own element, the setting's repeatable values stored in the element's settings array will be in display order.
Joe
