This document was generated from CDN thread
Created by: Joel Stanfield on 15-09-2010 11:33:44 PM
I recently had an ongoing issue with a 1700 system booting up to 5 times a day and usually while idle. Ended up that changing its IP address corrected this (static to DHCP). It does not appear that another device had that address. I also have seen high network errors, while in a call, can also cause a boot. Can any information be provided of conditions that will lead to intentional boots by the codecs?
