cdnadmin
Community Member
This document was generated from CDN thread
Created by: Chip Wofford on 13-10-2010 04:13:12 PM
The unit will not boot.  The console message is loading . . . searching . . . error . . .  missing or invalid application.
Is the API missing, corrupt, etc.  How can I fix this?
Subject: RE: MXP will not boot
Replied by: Roger Boe on 14-10-2010 08:54:36 AM
Hi Chip,
This means that the software image is corrupted and hence the unit cannot boot. You may have to send your unit back for repair. I suggest you contact your local support representative to help out diagnose this issue.
Best regards
Roger
