Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Scope Future on 31-05-2011 10:17:22 AM How can we get the user entered nomatch value. For example, at a particular menu if the caller enters a nomatch/invalid input(form/menu element) can I come to know what is the exact invalid input value entered by the caller. If yes, can anyone let me know how to get it. Thanks in Advance.
Subject: Re: New Message from Scope Future in Customer Voice Portal (CVP) - General Replied by: Janine Graves on 31-05-2011 10:35:14 AM Are you doing DTMF Only
The only way is to set maxnomatch to 1 and to modify the VoiceXML of the existing elements so that in addition to returning the value and value_confidence, they also return a variable called system.lastresult$.utterance. The VoiceXML Specification says that even on a 'nomatch' this variable should be set with whatever the caller entered. I haven't tested it on the Cisco system yet though.
Otherwise, you must make all DTMF entries valid and then test within the Studio app to see if the entry has the 'appropriate' value.
For example, if you use a Menu, use the 10-option menu and allow 0-9, and * If you are collecting using Digits, then set MinDigits to 1 and MaxDigits to something quite large, telling caller to enter # after their entry.
Thanks, Janine
On 5/31/2011 10:17 AM, Cisco Developer Community Forums wrote: > Scope Future has created a new message in the forum "General > Discussion - All Versions": > > -------------------------------------------------------------- > How can we get the user entered nomatch value. For example, at a > particular menu if the caller enters a nomatch/invalid input(form/menu > element) can I come to know what is the exact invalid input > value entered by the caller. If yes, can anyone let me know how to > get it. >  >  > Thanks in Advance. > -- > To respond to this post, please click the following link: > > <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/3973599> > > or simply reply to this email.
