cdnadmin
Community Member
This document was generated from CDN thread
Created by: Vinay Kanakath on 24-07-2012 06:00:57 PM
i am trying to use aAuth on a local webex quad server instance. i am using a java client for this. below is the code i am using. i am always getting a 500 server error with a message saying missing security token.
i have tried a very similar code snippet in c# and it works, i get the consumer key and consumer secret. Can anyone tell me what is missing in the below code?
<font size="2">
URL url =
</font>
new URL("http://f180373441956.il.bankofamerica.com:8080/api/quad/rest/management/apiconsumers"
);<font size="2">
</font>
//http://f180373441956.il.bankofamerica.com:8080/api/quad/rest/management/apiconsumers
HttpURLConnection conn =
(HttpURLConnection) url.openConnection();
<font size="2">
conn.setRequestMethod(
</font>
"POST"
);<font size="2">
conn.setDoOutput(
</font>
true
);<font size="2">
conn.setDoInput(
</font>
true
);<font size="2">
conn.setUseCaches(
</font>
false
);<font size="2">
conn.setAllowUserInteraction(
</font>
false
<font size="2">
conn.setRequestProperty(
</font>
"Content-Type"
,<font size="2">
</font>
"application/xml"
);<font size="2">
</font>
"Accept", "application/xml"
); <font size="2">
</font>
"Authorization","Basic userid:password"
);<font size="2">
</font>
<font size="2">
String xmlInput=
</font>
"<apiconsumer><callbackUrl>http://RNYXWTCRS11L1.corp.bankofamerica.com:8080</callbackUrl><description>Quad Mobile App</description><modifiedDate>1316741399291</modifiedDate><name>Quad Mobile App</name></apiconsumer>"
OutputStream out = conn.getOutputStream();
<font size="2">
Writer writer =
</font>
new OutputStreamWriter(out, "UTF-8"
out.write(xmlInput.getBytes());
conn.connect();
<font size="2">
System.
</font>
out.println("response code"
+conn.getResponseCode());<font size="2">
System.
</font>
out.println("response error "
+conn.getResponseMessage());<font size="2">
BufferedReader rd1 =
</font>
new
BufferedReader(<font size="2">
</font>
new
InputStreamReader(conn.getErrorStream()));<font size="2">
StringBuilder sb1 =
</font>
new
StringBuilder();
String line1;
<font size="2">
</font>
while ((line1 = rd1.readLine()) != null
sb1.append(line1);
<font size="2">
System.
</font>
out
.println(sb1.toString());<font size="2">
BufferedReader rd =
</font>
new
</font>
new
InputStreamReader(conn.getInputStream()));<font size="2">
StringBuilder sb =
</font>
new
StringBuilder();
String line;
<font size="2">
</font>
while ((line = rd.readLine()) != null
sb.append(line);
rd.close();
conn.disconnect();
writer.close();
out.close();
<font size="2">
System.
</font>
out
.println(sb.toString());
Subject: RE: Not able to consume oAuth api's using a java client
Replied by: Adrienne Moherek on 25-07-2012 05:40:50 PM
Hi Vinay,
This is the authorization part of the code that is not working for you:
The username and password need to be encoded for this to work.
Adrienne
Replied by: Vinay Kanakath on 25-07-2012 08:02:49 PM
Hi Adrienne
will normal utf-8 encoding work or it needs to be base 64? reason i ask is when i set the the request header with a base 64 encoded value i get an Illegal character exception
Replied by: Adrienne Moherek on 27-07-2012 03:45:56 PM
Hi Vinay,
It needs to be base 64 encoded. I have not had that problem with Basic Authentication. It should look like a string of numbers and letters.
Example:
1Authorization: Basic QWxhZGRpbjpvcGVuIHNlc2FtZQ==
Here's some info about Basic Authentication: http://en.wikipedia.org/wiki/Basic_access_authentication
Replied by: Vinay Kanakath on 02-08-2012 09:18:55 AM
Thanks Adrienne,forgot to add an update, this was resolved.
Cause:- turns out HttpUrConnection class has a bug with basic authentication. i changed the class to DefaultHttpClient and it now works
