This document was generated from CDN thread
Created by: null on 27-10-2006 11:38:34 PM
I'm trying to set a Nuance 8.5 specific parameter within my application. I'm setting it similar to how I'm setting the interdigittimeout, through VoiceXML properties. But the Nuance parameter wasn't set. I even tried appending 'nuance.' to the parameter and it still wasn't set. I'm curious to see if this is possible?
-sandra
Subject: RE: nuance specific parameters
Replied by: Vance Vagell on 01-11-2006 09:40:01 PM
Hi Sandra,
Is the parameter you are trying to set configurable via a VoiceXML property? If so, then the method you are using (similar to how you would set interdigittimeout) is correct: set it in the Root Doc configuration page of your voice app's properties in Audium Studio.
Which property are you trying to set, and what results tell you that it is not working?
Vance
