cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 08-12-2005 03:44:20 PM
Do you have sample code for an onCallStart element? I want to write java code that is automatically called on app start-up, without having the app developer do anything (kind of like a dllMain). Can I do this in Audium, or do I just write an action element and have the developer insert right after CallStart in the app?
I want my code to be called once only at app start and once at the start of every call. I will use a boolean flag to differentiate between the two.
Dan
PS - how do I remove a post? Vance gave me an answer to my last post yesterday. It is redundant now.
Subject: RE: onCallStart element
Replied by: Vance Vagell on 08-12-2005 05:41:46 PM
Hi Dan,
You can find a template for creating an On Call Start in the templates provided in this post. Additionally, the Receptionist tutorial application includes an On Call Start class (with full source code) that you could refer to for reference.
You cannot remove forum posts. We recommend that you add a note that says something along the lines of "This question has been resolved, thank you" to the post, so that if we come back to it at a later date we are aware that it has been resolved. You may wish to include a brief description of the resolution, but this is not required.
Vance
Replied by: null on 08-12-2005 08:16:50 PM
Thanks Vance, I'll post a note.
Dan
