cdnadmin
Community Member
This document was generated from CDN thread
Created by: Suhas Nandakumar on 10-04-2010 12:12:13 AM
  I am using XML API to simulate oneclick functionality. After creating the meeting through XML APIs , i want a APP to be shared immedietly when the user click on the meeting link
In my enable  options while creating the meeting, i have specified "showFilePath" and related options as per API doc. Can some one tell me how to have app sharing enabled automatically when a user/host joins the meetng
Suhas
Subject: RE: One Click Developer Question
Replied by: Kingsley Lewis on 15-04-2010 06:46:08 PM
Hi Suhas,
The application will not be shared immediately,  but doing the following will start the meeting, open the application and the application share dialog box.  Once the host clicks on the share button from the applicaiton share dialog box the sharing will start.
Please note that you need to URL encode the AL parameter.
https://sitename.webex.com/sitename/m.php?AT=HM&MK={meetingKey}&AS=AppView&AL=C%3A%5C%5CProgram+Files%5C%5Cyour+app%5C%5Cyour+app.exe
Thank you
-Kingsley Lewis
