cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 04-03-2005 09:30:20 PM
This is my understanding about onEndCall(). Please correct me if I am wrong
  • It is called when caller hangs up, Hang Up element is run or Application Transfer element is run.
  • It runs in the background, so it can be used to run time consuming job.
My application A's onEndCall() takes a long time to run and involves many database updates (> 15 seconds). When I use Application Transfer to go to application B, A's onEndCall() is called twice. The call is disconnected without getting into B.
This is part of A's activity log
[code:1:c2502e64a7]
167.209.148.32.1109971567325.2.888,03/04/2005 15:26:19,Subdialog_Return_Error,element,enter,
167.209.148.32.1109971567325.2.888,03/04/2005 15:26:40,,end,how,application_transfer
167.209.148.32.1109971567325.2.888,03/04/2005 15:26:40,,end,result,normal
167.209.148.32.1109971567325.2.888,03/04/2005 15:26:40,,end,duration,33
167.209.148.32.1109971567325.2.888,03/04/2005 15:26:56,,end,how,app_session_complete
167.209.148.32.1109971567325.2.888,03/04/2005 15:26:56,,end,result,normal
167.209.148.32.1109971567325.2.888,03/04/2005 15:26:56,,end,duration,49
[/code:1:c2502e64a7]
And this is A's error log
[code:1:c2502e64a7]
167.209.148.32.1109970940626.0.888,03/04/2005 15:15:53, SERVER ERROR: A VoiceXML exception occurred: error.badfetch
If I remove the database housekeeping code, it works fine.
Thank you.
Luong.
Subject: RE: OnEndCall issue
Replied by: Michael Bochynski on 09-03-2005 09:21:00 PM
Hi Luong,
The End-Of-Call class does not run in the background. The application should wait for the End-Of-Call to finish and then should perform a transfer.
Could you explain what do you mean by removing a database code? Do you remove the End-Of-Call class in full or just the code accessing a database?
Michael
Replied by: null on 10-03-2005 10:11:04 PM
[quote:5d323db037]
[/quote:5d323db037]
I just remove the code accessing the database
I am looking for a way to perform time consuming job at the end of a call. EndOfCall class works fine if I don't do application transfer. When I transfer to another Audium application, the call is dropped with error. Is there a work around?
Replied by: Michael Bochynski on 19-05-2005 03:51:37 PM
The possible workaround would be to spawn another thread with time consuming tasks. This would allow you to perform the application transfer and do the heavy-duty processing in the background.
Michael
