cdnadmin
Community Member
This document was generated from CDN thread
Created by: James Maudlin on 09-05-2011 12:49:02 PM
Had a situation where we had trouble installing the Oracle DB Instance.  After
ip.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; text-indent: 0.25in; font-size: 11pt; font-family: "Times New Roman"; }div.Section1 { page: Sectssueing the following command "DBCA" to launch the Database
Configuration Assistant application and going through the menu items.
When clicking finish and OK to create the DB - Nothing seems to happen - it should take about 15 min but goes no where.
I believe the VM machine resource allocation is the issue.  The VM that was created did not have enough resources to create the big table WebEx Social requires.  Re-installed and it took care of the problem.
Subject: RE: Oracle Data Base Instance Install Issue
Replied by: Christopher Chandler on 17-11-2011 11:23:04 AM
Marking as answered.
