Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: ahm gawad on 24-09-2010 01:08:47 PM HI ALL; I am using cvp outbound scripts from developer download section the problem is the cvp_dialer allways return "dialer response invalid" My GateWay is : 2811 and the same scripts is working well on another gateway 2821 THE output: *Sep 24 13:48:04.729: //32462//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 32464 *Sep 24 13:48:06.613: //32462//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 32464 *Sep 24 13:48:16.705: //32462//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 32464 *Sep 24 13:48:16.709: //32462//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXXX established *Sep 24 13:48:16.753: //32463//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 24 13:48:16.841: //32462//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received Thanks for your time.
Subject: RE: Outbound problem Replied by: Yaw-Ming Chen on 24-09-2010 04:33:27 PM Message is coming from cvp_obcallreq.tcl It's just follows the logic, looks like cannot get one of the following: proc dialer_response { } { global call_leg
if {[infotag get evt_gtd gtd_fac] && [infotag get gtd_attr_exists gtd_fac uus.1]} {
set outcome [binary format H* [object get gtd gtd_fac uus.1.dat]] puts -nonewline "******* CVP_OBCALLREQ: dialer call outcome: $outcome"
Subject: RE: Outbound problem Replied by: ahm gawad on 24-09-2010 10:27:26 PM That is right But why obcallreq always return dialer respone invalid Although the dialer create avalid GTD object and append avalid data to it and i have checked it
Subject: RE: Outbound problem Replied by: Yaw-Ming Chen on 24-09-2010 11:26:02 PM Collect deb voip app tcl as well so can look into more detail. Also since is is the cause by standard CVP tcl script so Cisco TAC should be able to help as well. Thanks !
Subject: RE: Outbound problem Replied by: Yaw-Ming Chen on 25-09-2010 03:33:55 AM *Sep 25 00:57:18.438: //32920//AFW_:/vtr_ev_gtd_object: Unable to create a GTD object entry This might be the clue. Thanks !
Subject: RE: Outbound problem Replied by: Yaw-Ming Chen on 26-09-2010 05:43:40 AM My suggestion is that contact Cisco TAC since this is standard CVP script, TAC will supoort it. You can post this question in CVP forum as well. My opinion is that there is not thing wrong with script.There are too many errors in the script output that you need to ask CVP support why ? For example : "call to poll CVP VXML outbound application failed, status ls_003 " that is from setuping a call to destination "ls_003 -- The call setup failed because of a lack of resources in the network" -- is not a common error for setup failure. Just like you said this might have something to do with setup, configuration. Thanks !
Subject: RE: Outbound problem Replied by: ahm gawad on 25-09-2010 01:07:36 PM Does this problem related to hardware resources or call configuration ?
Subject: RE: Outbound problem Replied by: ahm gawad on 25-09-2010 02:26:18 PM HERE IS THE COMPLETE DUMP : 28:00.899: //141//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:28:00.923: //141//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 143 *Sep 25 14:28:02.747: //141//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 143 *Sep 25 14:28:12.975: //141//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 143 *Sep 25 14:28:12.975: //141//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:28:13.019: //142//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:28:13.107: //141//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:28:30.899: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:28:30.931: //146//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=0116899EC7E811DF81C2A81FC4E601AD ******** CallID = 0116899EC7E811DF81C2A81FC4E601AD *Sep 25 14:28:30.955: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:28:31.131: //146//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:28:31.135: //146//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:28:31.143: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:28:31.151: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:28:31.151: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:28:31.155: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:28:31.155: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:28:31.155: //145//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:28:31.175: //145//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 147 *Sep 25 14:28:33.131: //145//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 147 *Sep 25 14:28:43.287: //145//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 147 *Sep 25 14:28:43.287: //145//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:28:43.331: //146//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:28:43.419: //145//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:29:01.155: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:29:01.187: //150//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=131F3DFDC7E811DF81CEA81FC4E601AD ******** CallID = 131F3DFDC7E811DF81CEA81FC4E601AD *Sep 25 14:29:01.211: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:29:01.383: //150//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:29:01.387: //150//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:29:01.395: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:29:01.403: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:29:01.403: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:29:01.407: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:29:01.407: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:29:01.411: //149//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:29:01.431: //149//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 151 *Sep 25 14:29:03.263: //149//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 151 *Sep 25 14:29:13.259: //149//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 151 *Sep 25 14:29:13.259: //149//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:29:13.303: //150//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:29:13.391: //149//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:29:31.407: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:29:31.439: //154//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=25275430C7E811DF81DAA81FC4E601AD ******** CallID = 25275430C7E811DF81DAA81FC4E601AD *Sep 25 14:29:31.459: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:29:31.639: //154//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:29:31.643: //154//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:29:31.651: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:29:31.655: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:29:31.659: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:29:31.663: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:29:31.663: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:29:31.663: //153//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:29:31.683: //153//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 155 *Sep 25 14:29:33.583: //153//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 155 *Sep 25 14:29:43.759: //153//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 155 *Sep 25 14:29:43.763: //153//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:29:43.803: //154//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:29:46.279: //153//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:30:01.663: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:30:01.695: //158//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=3730068BC7E811DF81E6A81FC4E601AD ******** CallID = 3730068BC7E811DF81E6A81FC4E601AD *Sep 25 14:30:01.719: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:30:01.895: //158//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:30:01.899: //158//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:30:01.907: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:30:01.911: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:30:01.915: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:30:01.919: //157//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:30:01.927: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:30:01.927: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:30:01.939: //157//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 159 *Sep 25 14:30:03.835: //157//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 159 *Sep 25 14:30:13.903: //157//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 159 *Sep 25 14:30:13.903: //157//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:30:13.947: //158//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:30:14.035: //157//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:30:31.927: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:30:31.955: //162//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=4939F1CEC7E811DF81F2A81FC4E601AD ******** CallID = 4939F1CEC7E811DF81F2A81FC4E601AD *Sep 25 14:30:31.983: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:30:32.159: //162//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:30:32.159: //162//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:30:32.171: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:30:32.175: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:30:32.179: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:30:32.179: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:30:32.179: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:30:32.183: //161//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:30:32.203: //161//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 163 *Sep 25 14:30:34.111: //161//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 163 *Sep 25 14:30:44.091: //161//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 163 *Sep 25 14:30:44.095: //161//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:30:44.135: //162//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:30:44.223: //161//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:31:02.179: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:31:02.207: //166//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=5B420A06C7E811DF81FEA81FC4E601AD ******** CallID = 5B420A06C7E811DF81FEA81FC4E601AD *Sep 25 14:31:02.235: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:31:02.411: //166//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:31:02.415: //166//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:31:02.423: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:31:02.427: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:31:02.431: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:31:02.431: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:31:02.431: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:31:02.435: //165//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:31:02.455: //165//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 167 *Sep 25 14:31:04.307: //165//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 167 *Sep 25 14:31:14.331: //165//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 167 *Sep 25 14:31:14.335: //165//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:31:14.375: //166//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:31:14.463: //165//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:31:32.431: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:31:32.459: //170//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=6D4A1FA0C7E811DF820AA81FC4E601AD ******** CallID = 6D4A1FA0C7E811DF820AA81FC4E601AD *Sep 25 14:31:32.487: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:31:32.663: //170//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:31:32.667: //170//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:31:32.675: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:31:32.679: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:31:32.683: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:31:32.687: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:31:32.687: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:31:32.687: //169//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:31:32.707: //169//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 171 *Sep 25 14:31:34.507: //169//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 171 *Sep 25 14:31:44.595: //169//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 171 *Sep 25 14:31:44.599: //169//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:31:44.643: //170//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:31:47.043: //169//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:32:02.687: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:32:02.715: //174//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=7F52D293C7E811DF8216A81FC4E601AD ******** CallID = 7F52D293C7E811DF8216A81FC4E601AD *Sep 25 14:32:02.743: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:32:02.919: //174//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:32:02.919: //174//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:32:02.931: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:32:02.935: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:32:02.939: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:32:02.939: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:32:02.939: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:32:02.943: //173//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:32:02.963: //173//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 175 *Sep 25 14:32:04.895: //173//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 175 *Sep 25 14:32:14.855: //173//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 175 *Sep 25 14:32:14.855: //173//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:32:14.899: //174//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:32:14.999: //173//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:32:32.939: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:32:32.975: //178//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=915AE8C6C7E811DF8222A81FC4E601AD ******** CallID = 915AE8C6C7E811DF8222A81FC4E601AD *Sep 25 14:32:32.991: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:32:33.191: //178//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:32:33.191: //178//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:32:33.203: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:32:33.207: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:32:33.211: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:32:33.211: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:32:33.211: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:32:33.215: //177//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:32:33.235: //177//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 179 *Sep 25 14:32:35.231: //177//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 179 *Sep 25 14:32:45.411: //177//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 179 *Sep 25 14:32:45.415: //177//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:32:45.455: //178//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:32:45.543: //177//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:33:03.211: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:33:03.239: //182//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=A3660DC5C7E811DF822EA81FC4E601AD ******** CallID = A3660DC5C7E811DF822EA81FC4E601AD *Sep 25 14:33:03.267: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:33:05.475: //182//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:33:05.479: //182//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:33:05.487: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:33:05.491: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:33:05.495: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:33:05.495: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:33:05.499: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:33:05.499: //181//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:33:05.519: //181//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 183 *Sep 25 14:33:07.443: //181//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 183 *Sep 25 14:33:17.423: //181//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 183 *Sep 25 14:33:17.427: //181//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:33:17.471: //182//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:33:17.559: //181//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:33:35.499: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:33:35.527: //186//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=B6A4CEF8C7E811DF823AA81FC4E601AD ******** CallID = B6A4CEF8C7E811DF823AA81FC4E601AD *Sep 25 14:33:35.555: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:33:35.727: //186//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:33:35.731: //186//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:33:35.739: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:33:35.743: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:33:35.747: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:33:35.751: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:33:35.751: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:33:35.751: //185//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:33:35.771: //185//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 187 *Sep 25 14:33:37.607: //185//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 187 *Sep 25 14:33:47.663: //185//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 187 *Sep 25 14:33:47.667: //185//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:33:47.707: //186//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:33:47.795: //185//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:34:05.751: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:34:05.779: //190//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=C8ACE52BC7E811DF8246A81FC4E601AD ******** CallID = C8ACE52BC7E811DF8246A81FC4E601AD *Sep 25 14:34:05.807: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:34:05.983: //190//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:34:05.987: //190//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:34:05.995: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:34:05.999: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:34:06.003: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:34:06.003: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:34:06.007: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:34:06.007: //189//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:34:06.027: //189//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 191 *Sep 25 14:34:07.843: //189//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 191 *Sep 25 14:34:17.983: //189//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 191 *Sep 25 14:34:17.983: //189//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:34:18.027: //190//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:34:18.115: //189//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:34:36.007: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:34:36.035: //194//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=DAB5998BC7E811DF8252A81FC4E601AD ******** CallID = DAB5998BC7E811DF8252A81FC4E601AD *Sep 25 14:34:36.063: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:34:36.239: //194//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:34:36.239: //194//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:34:36.251: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:34:36.255: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:34:36.259: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:34:36.259: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:34:36.259: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:34:36.263: //193//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:34:36.283: //193//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 195 *Sep 25 14:34:38.159: //193//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 195 *Sep 25 14:34:48.259: //193//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 195 *Sep 25 14:34:48.263: //193//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:34:48.307: //194//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:34:48.391: //193//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received *Sep 25 14:35:06.259: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:35:06.295: //198//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=ECBDAFBDC7E811DF825EA81FC4E601AD ******** CallID = ECBDAFBDC7E811DF825EA81FC4E601AD *Sep 25 14:35:06.311: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:35:06.491: //198//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:35:06.495: //198//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:35:06.503: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:35:06.511: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:35:06.511: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000
*Sep 25 14:35:06.515: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:35:06.515: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:35:06.515: //197//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:35:06.535: //197//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 199 *Sep 25 14:35:08.295: //197//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 199 *Sep 25 14:35:18.479: //197//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 199 *Sep 25 14:35:18.483: //197//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:35:18.523: //198//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:35:18.611: //197//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received % Type "debug ?" for a list of subcommands CCODAUSVG# CCODAUSVG# CCODAUSVG# CCODAUSVG#debug v *Sep 25 14:35:36.515: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:35:36.543: //202//TCL :/tcl_PutsObjCmd: TCL CVP: ******* Call arrived with ANI=sip:10.1.11.30, DNIS-OVERRIDE=, CALLID=FEC66218C7E811DF826AA81FC4E601AD ******** CallID = FEC66218C7E811DF826AA81FC4E601AD *Sep 25 14:35:36.571: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: call to poll CVP VXML outbound application established *Sep 25 14:35:36.747: //202//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:35:36.751: //202//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: sent dialer record to CVP_OUTBOUND.TCL, waiting for call outcome ... *Sep 25 14:35:36.759: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: facility GTD report containing dialer record *Sep 25 14:35:36.763: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: making call to poll CVP VXML application at <7788000> *Sep 25 14:35:36.767: %CALL_CONTROL-6-MAX_CONNECTIONS: Maximum number of connections reached for dial-peer 7780000 oice *Sep 25 14:35:36.767: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: ERROR: call to poll CVP VXML outbound application failed, status ls_003 *Sep 25 14:35:36.767: //-1//TCL :EE46DEE9D4000:/tcl_PutsObjCmd: ******* CVP_OUTBOUND: started poll timer *Sep 25 14:35:36.771: //201//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: assumed control of call with argument: <dnis=XXXXXXXXXX cli=8005551212 rna=30 id=1234 uui="uui info"> *Sep 25 14:35:36.791: //201//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_proceeding on call leg 203apl *Sep 25 14:35:38.683: //201//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_progress on call leg 20pli CCODAUSVG#debug voice application t CCODAUSVG#debug voice application tclcommands CCODAUSVG#debug voice application tclcommands CCODAUSVG#debug voice application tclcommands *Sep 25 14:35:48.859: //201//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_connected on call leg 203 *Sep 25 14:35:48.863: //201//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: ID = 1234: call to XXXXXXXXXX established *Sep 25 14:35:48.903: //202//TCL :/tcl_PutsObjCmd: ******* CVP_OBCALLREQ: dialer response invalid *Sep 25 14:35:48.991: //201//TCL :/tcl_PutsObjCmd: ******* CVP_DIALER: event ev_destroy_done received? <cr>
Subject: RE: Outbound problem Replied by: ahm gawad on 17-10-2010 07:12:34 AM finally i got it it is a bug on cisco i hope they solve it
Subject: RE: Outbound problem Replied by: CLAUDIO RIVAS on 22-08-2011 08:15:39 PM Sorry but TAC is not supporting this kind of scripts, they pointed me directly to the developer forum.
