Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Michel Henault-Ethier on 10-03-2009 01:36:28 PM Hi, I in a onStartCall method (onStartCall(CallStartAPI callStartData)) I instantiate a new object call and place it in Application Data. I can retrieve it in a new object in the same class without any problem as folloews:
However, when I try to get this object in another class extending DecisionElementBase in method doDecision(String name, DecisionElementData data) using the same code:
I get a casting exception. I am running the code in the Call Studio Debug and not on a VXML server. I have tried the same thing using the session scope with the same result:
java.lang.ClassCastException: Call at decisionNextMenu.doDecision(decisionNextMenu.java:46)
Any idea why I can't pass objects between classes using either the application or session scope? By the way I have tried using simple String and it works fiine... Thanks Mike
Subject: RE: Passing objects between classes using application or sesion scope Replied by: Ranjana Narayan on 11-03-2009 05:52:28 AM Hi Mike,
Workaround to escape this exception is to place your Call.class file under Cisco\CVP\VXMLServer\common\lib (if using VXML Server), else if you are working on Studio Debug, place the class under Cisco\CallStudio\eclipse\plugins\com.audiumcorp.studio.debug.runtime_<x.y.z>\AUDIUM_HOME\common\classes\. For all java objects that you store in the session (session data/ global data/ application data), make sure that the coresponding class is available at the common/lib to avoid ClassCastException.
Hope this helps, Ranjana Narayan.
Subject: RE: Passing objects between classes using application or sesion scope Replied by: Michel Henault-Ethier on 11-03-2009 02:37:45 PM Hi Ranjana, All is working fine now. Thanks for the help. Mike
Subject: RE: Passing objects between classes using application or sesion scope Replied by: Randall Kirchner on 26-06-2009 06:39:38 PM
Hi Mike,
Hi, I am having the same problem, but the fix you describe is not working for me. I have a StartUp java class that reads a comma delimited text file and creates a CallInfo object from each line. Then it puts each CallInfo object into a HashMap. In my Studio script then I can successfully get the HashMap out of session, but when I try to retrieve a CallInfo object out of the HashMap and cast it, I get ClassCastException. If I just retrieve it as an Object and call obj.getClass().getName() it tells me that it is a CallInfo object. So why can't I get it to cast? Thanks, Randy
