Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: GEERT DEWINTER on 17-02-2011 10:26:25 AM Hello, I want to add a line using the following : ------ $dirn = array( "pattern" => $tel, "routePartitionName" => $routepartition, "usage" => "Device", "description" => $description, "alertingName" => $description, "asciiAlertingName" => $description, "networkHoldMOHAudioSourceId" => 1, "userHoldMOHAudioSourceId" => 1, "shareLineAppearanceCSSName" => $css, "callForwardAll" => array( "forwardToVoiceMail" => $fwAvm, "callingSearchSpaceName" => $css, "destination" => $fwAnr, ), ); # $response = $client->addLine( array("newLine" => $dirn )); ------ Everything is created ok only the calling search space is not set. The calkinSearchSpace on the forward however is set fine. I must be missing something but I do not see it. Any help is welcome. Thanks, Geert
Subject: RE: PHP and ADDLINE using AXLAPI.wsdl Replied by: GEERT DEWINTER on 17-02-2011 12:12:47 PM I did find out that the shareLineAppearanceCSSName is not included in the SOAP-envelope: Request: addLine : <?xml version="1.0" encoding="UTF-8"?> <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="http://www.cisco.com/AXL/API/7.1"><SOAP-ENV:Body><ns1:addLine> <newLine> <pattern>449339</pattern> <description>TEST UDP</description> <usage>Device</usage> <routePartitionName>uk_phones</routePartitionName> <callForwardAll><callingSearchSpaceName>DOMM_Unlimited</callingSearchSpaceName></callForwardAll> <networkHoldMOHAudioSourceId>1</networkHoldMOHAudioSourceId> <userHoldMOHAudioSourceId>1</userHoldMOHAudioSourceId> <alertingName>TEST UDP</alertingName> <asciiAlertingName>TEST UDP</asciiAlertingName> </newLine> </ns1:addLine></SOAP-ENV:Body></SOAP-ENV:Envelope>
Subject: RE: PHP and ADDLINE using AXLAPI.wsdl Replied by: GEERT DEWINTER on 22-02-2011 04:28:04 AM Found the solution.
Subject: RE: PHP and ADDLINE using AXLAPI.wsdl Replied by: Simon Rood on 22-02-2011 04:51:42 AM What have you done?
Subject: RE: PHP and ADDLINE using AXLAPI.wsdl Replied by: GEERT DEWINTER on 22-02-2011 04:56:37 AM Checked the manual once again and found out that I needed to add : "presenceGroupName" =>
