cdnadmin
Community Member
This document was generated from CDN thread
Created by: Sergei Gorbunov on 11-05-2012 10:32:07 PM
Hi!
I want to drop call before called address receive any signaling. I've tryed call Call.drop() after CallActiveEv (first event in call queue) but not succeed, call drops only after CallCtlConnOfferedEv when called address already received call signaling. Is there any other method to drop call before called address receive any signaling?
Subject: RE: Prevent call creating
Replied by: David Staudt on 15-06-2012 06:02:35 PM
This won't be possible unless you 'intercept' the call before it is ever offerred to the target address.  There are two main mechanism of doing this:
JTAPI: create a CTI route point, and configure the UCM dial plan so that all calls intended for the target DN are sent to the CTI RP instead.  Your app can then handle the incoming call, decide on what to do with it, and either redirect it to the target DN or perform some alternative treament (drop the call or play a message, e.g.)
CURRI: Implement a Routing Rules Interface app attached to a UCM dial plan Route Pattern.  This causes UCM to make an HTTP/XML request to your app with the called/calling IDs, and allows your app to respond with a treament - e.g. allow the call to proceed to the target, reject it, play a message, etc.
http://developer.cisco.com/web/curri/home
Replied by: javavinay88 (simulated) on 19-06-2012 04:27:32 AM
for this purpse use CURRI.
Thaks & Best Regards
Vinay
