Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 15-12-2003 03:03:34 PM Hello, I've got an audio element, with dynamic configuration - a custom class implementing VoiceElementInterface and the getConfig() method. The class name is Testcl. I have placed it in /usr/local/Audium/applications/test1/java/application/classes/Testcl.class
I'm using NetBeans IDE, The class is compiled using javac version 1.3.1_06 with target 1.3. I'm running Audium server on Weblogic 7.0 with j2se 1.3.1_06 (the recommended version)
Every sample application executes correctly. When i execute my application using my custom class, the server won't start:
AUDIUM SERVER ERROR: An error occurred during initialization of the server: Testcl (wrong name: test1/java/application/classes/Testcl) ***
<Dec 15, 2003 3:47:16 PM CET> <Error> <HTTP> <101216> <Servlet: "Server" failed to preload on startup in webapp: "Audium" javax.servlet.ServletException: AUDIUM SERVER ERROR: An error occurred during initialization of the server: Testcl (wrong name: test1/java/application/classes/Testcl) at weblogic.servlet.internal.ServletStubImpl.createServlet(ServletStubImpl.java:912) at weblogic.servlet.internal.ServletStubImpl.createInstances(ServletStubImpl.java:833) at weblogic.servlet.internal.ServletStubImpl.prepareServlet(ServletStubImpl.java:773) at weblogic.servlet.internal.WebAppServletContext.preloadServlet(WebAppServletContext.java:2782) at weblogic.servlet.internal.WebAppServletContext.preloadServlets(WebAppServletContext.java:2739) at weblogic.servlet.internal.WebAppServletContext.preloadServlets(WebAppServletContext.java:2725) at weblogic.servlet.internal.WebAppServletContext.preloadResources(WebAppServletContext.java:2700) at weblogic.servlet.internal.HttpServer.preloadResources(HttpServer.java:563) at weblogic.servlet.internal.WebService.preloadResources(WebService.java:476) at weblogic.t3.srvr.ServletInitRunner$1.run(ServletInitRunner.java:50) at weblogic.security.service.SecurityServiceManager.runAs(SecurityServiceManager.java:780) at weblogic.t3.srvr.ServletInitRunner.run(ServletInitRunner.java:46) at java.lang.Thread.run(Thread.java:479)
what is the problem?
Subject: RE: Problem loading java class Replied by: Michael Bochynski on 15-12-2003 05:17:27 PM Hi Krzysztof,
It seems to be a package declaration error. If you put your class in the main directory for classes ( [i:aa8b35198e] [APPLICATION_NAME]/java/application/classes/[/i:aa8b35198e] ) please make sure that you [b:aa8b35198e]do not[/b:aa8b35198e] have any package declaration in your Java code.
If this won't help, you can also double check that Java class exists in a package that it should be placed in and the directory structure matches the package name. Moreover, please double check all the references to your Java class for small/capital letters, name of the class file, reference in the element using dynamic configuration. Please bear in mind, that especially Unix/Linux environment is extremely case-sensitive.
Hope this helps, Michael
Subject: RE: Problem loading java class Replied by: null on 16-12-2003 10:27:08 AM Hi,
actually it was the package case. thank you for the fast response
