This document was generated from CDN thread
Created by: Sukhadeo Prasad on 14-09-2010 12:03:04 PM
While running applihcation update batch file, I am getting following error:
"There was a problem loading classes local to the application..."
I wrote few custom classes. This was running till yesterday. Then I added custom say it smart plugin, and it stopped.
If i remove all custom class class files from the VXMLServer, the update batch succeeds.
Then I copy the class files, and run the application. Surprisingly application runs and shows the changes done in the application. Means class files are valid and comply to CVP standard interfaces.
Subject: RE: Problem loading the application
Replied by: Sukhadeo Prasad on 15-09-2010 07:45:09 AM
I am sorry. By mistake the custom jar file was got copied to more then one places on the VXML Server.
Thanks.
