cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 24-06-2005 08:51:24 PM
I am having a problem when using suspendServer and resumeServer admin scripts. They work fine, but aren't able to write out the global_status.xml file. I get the following message:
The server has been resumed. All applications have been returned to their indiv
idual running or suspended states.
However, we encountered an error that will prevent the Audium Server from starti
ng when the application server is restarted. The error was: There was a problem
parsing the XML file C:\Program Files\VistaGenXMLEdition\conf\global_status.xml
. The root cause of this error was: Document root element is missing.
The xalan.jar file in the class path is the one in AUDIUM_HOME/lib.
Subject: RE: Problem with admin scripts
Replied by: Vance Vagell on 24-06-2005 10:14:52 PM
Hi Paul,
This error is generated when using Java 1.4 to run VistaGen. Note that VistaGen is certified with Java 1.3. We strongly suggest using only certified configurations, especially for production environments.
Vance
