rafa_br_1
Community Member
Good afternoon,
Guys I have a CISCO 2800 with CME and recentil it begun problem:
The CME has 2 E1 links, a configured with PRI and the another one with R2-Digital, the principal link is the second . Sometimes the CME takes to send the numbers to the E1. The normally time is 300ms(it normal time to my provider answer)but it longer 8 seconds (and my provider gives timeout) then the CME redirect to a channel from my second E1(but the calling longer a lot to complete).
Do you know whats it can be?
Configurations E1:
controller E1 0/0/0
pri-group timeslots 1-31
description [ xxx ]
controller E1 0/0/1
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
  country brazil use-defaults
  metering
  category 2
  answer-signal group-b 1
description [ xxxx]
Regards.
Rafael.
Greeshma Bernad
Thank you for your posting and interest in the Cisco Support Community.  For best practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions
For technical questions related to a Cisco Product or Technology, we encourage you to post on the Network Professionals Forum (NetPro). For your specific issue, you can go to IP Telephony forum
