Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Subject: RE: New Message from Arun Kumar in Customer Voice Portal (CVP) - General Di Replied by: Hemal Mehta on 15-04-2012 05:55:56 PM That is possible as if you pass certain parameters on .NET side, you may not get the right code generated. Have you tried using axis libs or eclipse built in plug in for Web services. Let me know, if you need any details. Hemal ________________________________ From: Cisco Developer Community Forums [[email protected]] Sent: Sunday, April 15, 2012 4:14 PM To: [email protected] Subject: New Message from Arun Kumar in Customer Voice Portal (CVP) - General Discussion - All Versions: Problem with calling .NET web services using Studio web service element
Arun Kumar has created a new message in the forum "General Discussion - All Versions":
-------------------------------------------------------------- All, I am having issues calling a .NET webservices using the webservices element. I just cannot get the method with correct return type when I use the inbuilt web services element. I never had issues alling java web services. Can somebody guide. -- To respond to this post, please click the following link:
Subject: RE: New Message from Hemal Mehta in Customer Voice Portal (CVP) - General D Replied by: GEOFFREY THOMPSON on 15-04-2012 06:01:56 PM I call Web services by hand in a custom Action element using Axis. You get complete control. I don’t have much faith in the Web Services Element.
Regards, Geoff This document was generated from CDN thread
Created by: Arun Kumar on 15-04-2012 05:14:26 PM All, I am having issues calling a .NET webservices using the webservices element. I just cannot get the method with correct return type when I use the inbuilt web services element. I never had issues alling java web services. Can somebody guide.
