This document was generated from CDN thread
Created by: null on 30-11-2006 12:16:35 AM
Please help....
I have developed a custom decision element which uses jar files & DLL files. I am able to compile in Audium studio under Java project.
1. Copied the .class file into ..\<application>\deploy\java\application\classes folder.
2. Copied required jar files into ..\<application>\deploy\java\application\lib folder
3. Even copied jar files into ..plugin\common\lib folder.
When I close and reopen the Audium studio, I do not see the element under Local Elements folder.
I have other decision element class files developed and they are listed in the Local Elements folder.
I am able to compile the same in DOS window and run the application (of course without Audium specific code).
Appreciate quick response.
Subject: Re: Problem with custom decision element
Replied by: null on 30-11-2006 06:48:10 PM
Please ignore my earlier post. I figured out the problem.
In the decision element's getSettings() method, I had declared Settings[6] variable and was assigning to Settings[0] to Settings[4]. This caused the problem.
I wish Audium studio wrote to an error log. It would have been so easy to figure out the problem and fix.
Subject: RE: Re: Problem with custom decision element
Replied by: Michael Bochynski on 30-11-2006 07:51:36 PM
Hi Bhaskar,
Audium Studio 5.1 does write Java exceptions to the log. Note that the Audium Error Log is not turned on by default. If your custom element does not show up in the Element panel, the Error View will most likely have the exception logged.
To enable the Audium Error Log, start Studio and go to Window -> Show View -> Audium Error Log. The additional tab will be displayed in the bottom section of Studio.
Hope it helps,
Michael
Replied by: null on 30-11-2006 09:58:35 PM
I am still using Audium Studio 3.4.5. Does this editor log the errors as in 5.1 ?
Replied by: Michael Bochynski on 30-11-2006 10:00:52 PM
The Audium Error Log is not available is Studio 3.4.5. We would strongly suggest to upgrade to the most recent release of Studio.
Michael
