cdnadmin
Community Member
This document was generated from CDN thread
Created by: Reinhard Schloeglhofer on 02-08-2010 08:00:26 AM
I have a strange behaviour with the regsub command:
There are the following variable settings:
lookupSEARCHPATTERN is set to {200([0-9]+)}
ani is set to 20025
lookupREPLACEPATTERN is set to {999\1}
When i call the regsub command
regsub -all $lookupSEARCHPATTERN $ani $lookupREPLACEPATTERN anicorr
in the tclsh, it correctly returns 99925 to variable anicorr.
Doing the same during an incoming call, the error message
Aug 02 09:45:41 172.24.10.66 23368: Aug  2 07:45:40.484: //1472//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
Aug 02 09:45:41 172.24.10.66 23369: Aug  2 07:45:40.484: TCL script failure
Aug 02 09:45:41 172.24.10.66 23370:     Result:
Aug 02 09:45:41 172.24.10.66 23371:              couldn't compile regular expression pattern: quantifier operand invalid
Aug 02 09:45:41 172.24.10.66 23372: Aug  2 07:45:40.484:     TCL script failure errorInfo:
Aug 02 09:45:41 172.24.10.66 23373:             couldn't compile regular expression pattern: quantifier operand invalid
Aug 02 09:45:41 172.24.10.66 23374:     while executing
Aug 02 09:45:41 172.24.10.66 23375: "regsub  $lookupSEARCHPATTERN $ani $lookupREPLACEPATTERN anicorr "
Aug 02 09:45:41 172.24.10.66 23376:     (procedure "act_Setup" line 1250)
Aug 02 09:45:41 172.24.10.66 23377:     invoked from within
Aug 02 09:45:41 172.24.10.66 23378: "act_Setup"
is returned and the call is interrupted.
I have dumped the variable content and it is correct (output is "regsub -all {200([0-9]+)} 20025 {999\1} anicorr")
When i call the statement
  during the call (without using variables) it is ok
Can someone please help me ?
Thanks and kind regards
Reinhard
Subject: RE: Problem with regsub in TCL script
Replied by: Reinhard Schloeglhofer on 02-08-2010 10:58:44 AM
Hi Raghavendra,
Thank you for your response.
This code is also working in my application. The difference is, that i set the values in the application configuration:
application
service xxx
param lookupSEARCHPATTERN {200([0-9]+)}
param lookupREPLACEPATTERN {999\1}
I am sure, that the variables are correct, because i made a puts before:
puts "($ani,$dnis) regsub -all $lookupSEARCHPATTERN $ani $lookupREPLACEPATTERN anicorr"
The puts command printed out
(20025,1011) regsub -all {200([0-9]+)} 20025 {999\1} anicorr
Thanks, kind regards
Reinhard
Replied by: Reinhard Schloeglhofer on 02-08-2010 12:11:49 PM
Hi Raghavendra,
Thank you for your help ! I don't understand why, but now it works.
kind regards
Reinhard
Replied by: Raghavendra Gutty Veeranagappa on 02-08-2010 10:39:33 AM
Hi Reinhard,
i have tested following code which returns 99925 , i am not getting error
proc act_Setup { } {
set lookupSEARCHPATTERN {200([0-9]+)}
set ani 20025
set lookupREPLACEPATTERN {999\1}
puts "anicorr:$anicorr"
Please post your code so that we can test and let you know
Raghavendra
Replied by: Raghavendra Gutty Veeranagappa on 02-08-2010 11:37:13 AM
Hi Reinhard,
Please run following commands and test it will work
application
service xxx
param lookupSEARCHPATTERN 200([0-9]+)
param lookupREPLACEPATTERN 999\1
Raghavendra
Replied by: Raghavendra Gutty Veeranagappa on 02-08-2010 01:41:11 PM
Hi Reinhard,
Because you will get configuration param values as string , so you are passing string with { } value to the regsub command not as regular expression
Raghavendra
