cdnadmin
Community Member
This document was generated from CDN thread
Created by: MARCUS STOLZENBERG on 21-10-2009 07:33:42 PM
I have a little problem with AXL and SOAP/PHP.
As base I use the php sample code I found in the wiki.
Now I try the following:
$client->updatePhone(array("name"=>"SEP001111111111","ownerUserId"=>"cisco"));
Both the device and the user are available in the UCM. If I set the ownerid with the help of the ccmadmin page everthing is fine.
If I run the php script I get the following error:
SOAP-ERROR: Encoding: object hasn't 'enableExtensionMobility' property
Any idee why this happens?
Best Regards,
Marcus
Subject: RE: Problem with updatePhone (PHP)
Replied by: David Staudt on 21-10-2009 10:00:47 PM
The online UCM help has this to say about the Owner User ID field:
    <a name="wp1407494"> </a>
From the drop-down list box, choose the user ID of the assigned phone
user. The user ID gets recorded in the call detail record (CDR) for all
calls made from this device.
<a name="1407495"></a>
Note : Do not configure this field if you are using extension mobility. Extension mobility does not support device owners.
I gather this means that you shouldn't (can't?) have E/M configured as well as this field.  If E/M is enabled for this device, perhaps that is triggering AXL to reject setting the ownerUserID...can you confirm?
In any case, you may need to always send enableExtensionMobility (i.e. = false) when setting the ownerUserID.
Replied by: MARCUS STOLZENBERG on 24-10-2009 07:55:18 PM
Hi David,
Thanks! You are right.
$client->updatePhone(array("name"=>"SEP001122334455","enableExtensionMobility"=>"false","ownerUserId"=>"cisco"));
and everything is fine.
Best Regards,
Marcus
