This document was generated from CDN thread
Created by: Juned Ahsan on 17-08-2009 08:12:48 AM
I am trying to build Dyanmic Menus in CVP studio using the java code. I need to add multiple "nomatch_audio_group" and "noinput_audio_group" audio groups. Here is my code snippet, please provide some pointers how to add multiple audio groups of a type and have different audios set in those audio groups.
/////////////////////////////////////////CODE SNIPPET//////////////////////////////////////////////////////////////////
//Get MAX No Input and No Match values
String strMaxNoInputCount = (String)elementAPI.getSessionData("MaxNoInput");
String strMaxNoMatchCount = (String)elementAPI.getSessionData("MaxNoInput");
if( strMaxNoInputCount !=null || !"".equals(strMaxNoInputCount.trim())) {
maxNoInputCount = Integer.parseInt(strMaxNoInputCount);
if( strMaxNoMatchCount !=null || !"".equals(strMaxNoMatchCount.trim())) {
maxNoMatchCount = Integer.parseInt(strMaxNoMatchCount);
elementAPI.addToLog(elementName,"MaxNoInput Count : " + maxNoInputCount);
elementAPI.addToLog(elementName,"MaxNoMatch Count : " + maxNoMatchCount);
//NO MATCH
VoiceElementConfig.AudioGroup nomatchAudioGroup[] = new VoiceElementConfig.AudioGroup[maxNoMatchCount+1];
defaults.removeAudioGroup("nomatch_audio_group", 1);
for(int j = 1 ; j < maxNoMatchCount ; j++) {
elementAPI.addToLog(elementName,"Creating AudioGroup " + "nomatch_audio_group");
nomatchAudioGroup = defaults.new AudioGroup("nomatch_audio_group", true , 1);
//Fetch prompts, options and set in NO INPUT GROUP
String strnoMatchAudioCount =(String) menusProperties.get(menuId+"_NM_PP_COUNT");
int noMatchAudioCount = Integer.parseInt(strnoMatchAudioCount);
VoiceElementConfig.StaticAudio noMatchAudio = null;
elementAPI.addToLog(elementName,"CONFIGURATION UPDATE : No Match Audio Group");
for (int i = 1 ; i<=noMatchAudioCount ;i++){
elementAPI.addToLog(elementName,"No Match Name : " + menuId+"_NM_PP_"+i);
elementAPI.addToLog(elementName,"No Match Value : " + menusProperties.getProperty(menuId+"_NM_PP_"+i));
noMatchAudio = defaults.new StaticAudio("",menusProperties.getProperty(menuId+"_NM_PP_"+i));
nomatchAudioGroup.addAudioItem(noMatchAudio);
elementAPI.addToLog(elementName,"No of audios set in audio group : " + nomatchAudioGroup.getName()
+ " is : " + nomatchAudioGroup.getNumAudioItems());
defaults.setAudioGroup(nomatchAudioGroup);
//For the last audio group to play silence only
nomatchAudioGroup = defaults.new AudioGroup("nomatch_audio_group", true,1);
elementAPI.addToLog(elementName,"Adding NoMatchGroup ");
VoiceElementConfig.StaticAudio finalNoMatchAudio = defaults.new StaticAudio("","ID_OPT_9.wav");
nomatchAudioGroup.addAudioItem(finalNoMatchAudio);
elementAPI.addToLog(elementName,"Audio Group Name : " + nomatchAudioGroup.getName());
elementAPI.addToLog(elementName,"No of audios set in AudioGroup : " + nomatchAudioGroup.getName()
+ " is : " + nomatchAudioGroup.getAudioGroupCount());
