cdnadmin
Community Member
This document was generated from CDN thread
Created by: Doros Antoniadis on 27-10-2009 01:27:26 PM
We are trying to build a custom T2 room (for 4 persons) using only one C90 with 2 cameras. Also in front of every 2 persons there will be a touch-pad for the control of the system and -if possible- for the presentation.
The issues:
1) Which are the (2X) maximum\ optimal resolution video streams (resolution and frame rate) we can receive from a C90 (remote site) and how can we obtain them? What are the b/w requirements for these 2 streams and also (optionally) for an additional H.239 stream for presentation?
2) Can we have directional audio from a C90 and how can we do that?
3) Decide (depending on the above answers) if a) we need to use an external video processor for zoom/ pixel mapping or b) if we need an additional codec (e.g a C20) for the 2nd video stream/ presentation and how can we achieve the audio sync between the 2 codecs.
Thanks!
Subject: RE: Problems concerning a Custom T2
Replied by: Roger Boe on 29-10-2009 10:42:47 AM
Hi Doros,
1) With a C90 you can send 1920*1080 30fps in one stream and up to UXGA 1600*1200 in the second stream (PC resolution), or you can also send 1920*1080p30 in the second stream as a live resolution. The C90 will only support 2 streams in a point to point call i.e. main and dual stream (H.239). If you are planning to use full resolutions in both streams I would recommend to dial at 6Mbps which gives 3Mbps for each stream.
2) This is currently not supported in any other system than the T3.
3) If you need more then 2 streams you will need to add another codec. In such a scenario all audio should run through one codec and this codec will take care of the lipsync. NOTE! There is no lipsync on the dual stream.
Best regards
Roger
Replied by: Doros Antoniadis on 29-10-2009 11:50:30 AM
Roger Boe:
Hi Doros,
Best regards
Roger
Hi Roger ant many thanks for your answer!
So,
1) If the available bandwidth for the T2 system is 4 mbps, what is your suggestion? Of course we must forget the scenario of a 3d stream via a second codec, but still are we able (with 4mbps) to make a 2 X 1080p@30 call or not? Will it be good/ sufficient/ better to make a 2 X 720p@30 call? Besides that, if we want to make some local demo calls in 6 mbps, how can we use/ force 1080p@30 in the 2nd stream?
2) I understand that we must forget the directional audio experience... It's a pity!
3) What if the remote site could send us 1 stream created by 2 cameras (via video compositor) and in a 2nd stream the presentation? Would this be a good solution? And then we can locally split the 1st stream using a video processor and send 1st camera in 1st monitor and 2nd camera in 2nd monitor. What resolutions could we achieve by doing that? Will this create a good/ sufficient user experience?
Can you explain further what you are saying about lipsync? Do you mean that we are going to have problem in lipsync even by using only one codec and 2 X 1080p@30 streams for the 2 cameras of the remote site?
Doros
Replied by: Roger Boe on 29-10-2009 02:11:49 PM
Hi Doros,
1) The C90 is using the optimum resolution scheme and will only do 1080p from about 2,3Mbps. So in this case you would typically use 720p when you have 2Mbps for the main channel and 2Mbps for the duo channel. The content channel is normally set to sharpness and will prefer sharpness over motion, it will therefore maintain the native input resolution as long as it is able to sustain more then 4fps and the other end supporting this. The input resolution must also be one that is supported for encoding, if not it will be scaled to fit the closest match. Using 6Mbps the second stream will have 3Mbps and you will then get 1080p if the input resolution is 1080p. You can also get 1080p at 1Mbps if the input resolution is 1080p and the content channel is set to sharpness.
3) This is possible. Resolution you will get then is simple:
1920/2 =  960
1080/2  = 540
After splitting the images you would then have two images of 960*540. This is close to wPAL (1024*576) and would be close to typical real wide screen TV broadcasts you get over digital cable TV. If this is good enough for your applicable must be evaluated by you. It will also depends on how large screens you are using, how far away the audience if from the screen etc.
Lipsync: H.239 doesn't define any audio for the second stream, so all audio will run through the mainstream and all lipsync mechanisms is only working with the mainstream.
Cheers
Roger
Replied by: Doros Antoniadis on 29-10-2009 02:58:35 PM
Roger Boe:
I need more help on that...
I tried locally from a C90 to send 2 x 1080p @ 6mbps to a C20. I called the C20 @ 6mbps and achieved 1 stream @ 1080p. When I tried to send a second stream (from an attached 1080p camera), the 1st stream dropped to 720p and the 2nd stream was 448p. I tried then the other way and called from the C20 the C90 @ 6 mbps. I achieved again 1 stream@ 1080p and when I pressed the presentation button I got 2 streams @ 720p.
Is this a normal behavior (both ways) due to some limitations of the C20? You mean that if the remote site was a C90, by using 6mbps I would have achieved 2 x 1080p?
And finally (?) what do you mean by "You can also get 1080p at 1Mbps if the input resolution is 1080p and the content channel is set to sharpness."?
Doros
Replied by: Roger Boe on 29-10-2009 03:22:15 PM
Doros Antoniadis:
Doros
Yes, this is a limitation of the C20. The C20 can maximum do wXGA in the content channel (H.239).
Doros Antoniadis:
Actually you can't set the content channel to sharpness. What I meant was that if the video source used for the content channel is set to sharpness, then the unit will prefer sharpness over motion and you will be able to sustain a 1080p stream as 1Mbps as long as the frame rate doesn't drop lower then 4 fps. With 1Mpbs  you should get much more then 4fps, so this shouldn't be any issue.
Best regards
Roger
