This document was generated from CDN thread
Created by: null on 28-06-2007 03:29:19 PM
As per CVP document ivr script/audium application should start with subdialog_Start and end with subdialog_End. In our demo application caller can be transfer to an extension
(extension number is passed as session data to SubDialog_Return
GT{XXXX} ) or if caller can hangup after they hear the information they want in the call.
Our question is how we can force Hang-up in the application,
If all calls has to end in Subdialog.?
Can you point us to a topic / document which explains about this
Following is our lab setup
Cisco CVP 4.x
CVP Studio
Cisco s8700 router
Note:We do not have ICM
Chaitra
Subject: RE: Question on SubDialog_Return Element
Replied by: Janine Graves on 14-07-2007 12:41:32 AM
If you don't have ICM, then I believe that you can use a HangUp element in place of a Subdialog Return element.
CVP Studio has a Transfer element in it, and you could use that to perform the transfer. It creates a Vxml page (containing a VXML <transfer> element) that is executed by the Vxml Gateway. With this element, you can perform a bridge or a blind transfer. And then you can end the CVP Studio application using a Hangup element.
If you need to use the SubdialogReturn to pass the data to the Vxml Gateway to perform the transfer (instead of using the Transfer element above), then it will be up to the Vxml Gateway to hang up from the caller. The CVP Vxml Server license should be freed automatically as part of the SubdialogReturn.
Janine
www.TrainingTheExperts.com
