This document was generated from CDN thread
Created by: null on 24-09-2003 09:26:46 AM
I'm using an evaluation version of Audium Builder 3.2.2.
1) The elements are really an advantage to develop faster voice applications.
However, I noticed that they were very often depending on the language.
Indeed, a date or a phone number are spelled in a different way in english and in french.
Have you different versions of this library of tools to be compliant with several languages ?
2) For a menu, I would like to allow several voice possibilities for each option (for example "pen", "pencil" and "crayon" for the value "pencil"). How can I do ?
3) I have a page which describes a common behaviour (for example a code capture) and this page can be called from several places in my application (access to my personnal message box, access to my billing account). And I would like an automatic return to the calling context to go on the call flow. Can I make it possible without decision element ?
4) If I configure dynamic grammars for a form, how can I describe the outputs of this element leading to next elements according to the semantic ?
Thanks in advance.
Subject: RE: Questions
Replied by: null on 24-09-2003 03:26:21 PM
The answers to your questions follow:
1) Audium does not ship with elements using any other languages. Some elements will function in other languages (such as Digit) because they use built-in grammars that you can change on the voice browser side. Other elements such as Form are generic enough to be able to handle grammars of any language provided the voice browser supports it). For the rest, unfortnately, your only option would be to create your own elements or write VoiceXML Insert elements.
2) The menu settings specifying individual options ("Option X DTMF" and "Option X Voice") are repeatable settings, meaning you can specify multiple values for them. Simply right click on the setting name, choose to add another instance, and type in your extra utterance. You can do this as much as you want, which is how you can make synonyms. See the voice element specification document for more information on this.
3) You will have to use a decision element to figure out where you came from and return to the calling context.
4) When you make an external grammar to be used in a form (dynamic or not) you have to conform to a naming convention to represent the result. Please refer to the element specification documentation about Form for details about this convention. Also note that the Form element was significantly improved in Audium 3.3, providing significantly more functionality.
Hope this helps!
