cdnadmin
Community Member
Subject: putxml using jQuery $.ajax() 405 error
Replied by: Phil Gorman on 08-02-2012 11:07:52 AM
I've used the used jQuery script below to post a XML string to the putxml method but I get the following error returned:
OPTIONS http://<ip>/putxml 405 (Method Not Allowed)
XMLHttpRequest cannot load http://<IP>/putxml. Origin http://livamx01 is not allowed by Access-Control-Allow-Origin.
Any Ideas?
$('#Move').bind('click', function(){
                        var str = '<Command><Camera><PositionSet command="True"><CameraId>1</CameraId><Pan>200</Pan><Tilt>200</Tilt></PositionSet></Camera></Command>';
                        $.ajax({
                                type: "POST",
                                contentType: "text/xml",
                                processData: false,
                                url: "http://ip/putxml",
                                datatype: "text/xml",
                                data: str,
                                success: function(msg) {
                                    alert('hello!');
                                error: function(requets, error) {
                                    alert('error:' + error);
God Bless,
Phil.
This document was generated from CDN thread
Created by: David Bruun-Lie on 08-02-2012 01:55:43 PM
Hi Phil,
Change the url part to url: "http://ip/formputxml",
ps: you also need to authenticate this request with basic authentication
Cheers,
David
