Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Stephan Steiner on 03-02-2009 05:06:22 PM Unfortunately, that's the way it works. I opened a case on this and they're going to change the documentation.. not the functionality even though I pointed out that this used to work as expected on CCM4 (well it's not exactly the same but DeviceListX.asp contained devices in Unknown state). Basically you need to query the device table, make your serviceability request, then compare the results.. anything that is a device but not in the serviceability output is in status unknown.
Subject: Re: SelectCmDevice, SelectCmDeviceSIP - status filter problem Replied by: David Staudt on 03-02-2009 09:41:43 PM Stephen would you mind sending me the bug # or case#: [email protected]
Subject: RE: Re: SelectCmDevice, SelectCmDeviceSIP - status filter problem Replied by: piotr wozniak on 11-02-2009 01:16:54 PM
You mean it's not a bug? So what is expected behavior of querying devices by "Unknown" status? The documentation is constantly being copy-pasted with syntax errors like here: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/devguide/6_0_1/ccmdvCh2.html#wp43191 - just look at the section "<span class="content">Array of Items for Which Search Criteria Are Specified</span>".
You mean that I shoul make AXL getPhones query to compare results with SelectCmDevice? But that requires different user permissions so it's not a complete solution. Regards, Peter
Subject: RE: Re: SelectCmDevice, SelectCmDeviceSIP - status filter problem Replied by: piotr wozniak on 19-04-2010 10:18:14 AM As you can see, in the 8.01 documentation errors are still being copy-pasted: http://www.cisco.mn/en/US/docs/voice_ip_comm/cucm/devguide/8_0_1/serviceability.html#wp1053885 I haven't tested AXL functionality on this version yet, but that doesn't make me feel good about this...
The following example specifies an array that contains the IP Address or Device Name of the items for which a real-time status is required.
