Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Mohamed Fahmy on 23-07-2010 01:21:46 PM I have a simple recprding app running on a n 12.4(24)T gateway. No matter what I do, the caller gets cut off after 30 seconds of recording. Any advise would be appreciated.
Hello Wes, I had the same problem yeterday, I know it's a long time since you posted this, Kindly tell me how did you manage to solve it. Is it a voice gateway limitation? if yes, should i use the HTTP recording instead? I use RAM then submit the data to HTTP server (like you did). And that because I didn't understand the syntax of HTTP recording. Thanks in advance.
Subject: RE: VXML Record issue Replied by: Raghavendra Gutty Veeranagappa on 26-07-2010 09:48:28 AM Hi Mohamed Fahmy, You might try setting memory recording limits in your voice gateway configuration
For Example: Router(config)# ivr record memory session 1000
Router(config)# ivr record memory system 15000
Thanks Raghavendra
Subject: RE: VXML Record issue Replied by: Mohamed Fahmy on 04-08-2010 09:49:54 AM
Hi Mohamed Fahmy,
Yes Raghavendra, that was the problem. Thank you very much. Best Regards
