cdnadmin
Community Member
This document was generated from CDN thread
Created by: tdaATT1153 (simulated) on 16-06-2011 04:12:10 PM
I am logging in as agent 012345 using the CTI Toolkit Combo Desktop.NET sample program. I am also running another app using CTI OS 8.5 that performs an SetAgentMode with the same agent id of 012345 and a periperial id. When an inbound call arrives I get the same event message information except that the CTI Toolkit Combo Desktop.NET sample program which is loogged in, gets the CallVariable and ECC data BUT the other app that is not logged in does NOT get the CallVariable and ECC data.
Is the this normal behavior or is there something else I should be doing?
Subject: RE: New Message from tdaATT1153 (simulated) in Computer Telephony Integrati
Replied by: David Lender on 20-06-2011 01:10:22 PM
What is your other app?  Does it also use the .NET Cil?  You are getting call and agent state events on it but missing the call data?  Which event are you looking for call data on in your other app?   If both apps are logged in to the same agent they should both get the call data.
