cdnadmin
Community Member
Subject: RE: New Message from Alejandra Moreno in Administration XML (AXL) - Adminis
Replied by: Erick Wellnitz on 02-09-2011 01:56:40 PM
It¿s not TOD Access.  It¿s most likely the ¿Enable Mobile Connect¿ box in the CUCM interface.  You¿ll need to modify whichever parameter this is via AXL to stop the RD from ringing.
From: Cisco Developer Community Forums [mailto:[email protected]]
Sent: Friday, September 02, 2011 10:57 AM
To: [email protected]
Subject: New Message from Alejandra Moreno in Administration XML (AXL) - Administration XML Questions: remote destination
Alejandra Moreno has created a new message in the forum "Administration XML Questions":
Is it ok to add a remote destination without any TODAccess? The AXL interface doesn't complain when I add a remotedestination without the todAccess tag. Then I update the remote destination to set the 'enable' flag but I have encountered strange behaviors. Sometimes after disabling the remote destination using AXL modifyRemoteDestination the remoteDestination still rings. Is it because I have no TODAccess defined? I want to have it all the time ringing but to be able to switch on/off the enable flag. Any ideas?
Thanks.
To respond to this post, please click the following link:
<http://developer.cisco.com/web/axl/forums/-/message_boards/view_message/4444376>
or simply reply to this email.
CIRCULAR 230 DISCLOSURE: Pursuant to Regulations Governing Practice Before the Internal Revenue
Service, any tax advice contained herein is not intended or written to be used and cannot be used
by a taxpayer for the purpose of avoiding tax penalties that may be imposed on the taxpayer.
CONFIDENTIALITY NOTICE:
This electronic mail message and any attached files contain information intended for the exclusive
use of the individual or entity to whom it is addressed and may contain information that is
proprietary, privileged, confidential and/or exempt from disclosure under applicable law.  If you
are not the intended recipient, you are hereby notified that any viewing, copying, disclosure or
distribution of this information may be subject to legal restriction or sanction.  Please notify
the sender, by electronic mail or telephone, of any unintended recipients and delete the original
message without making any copies.
NOTIFICATION:  Katten Muchin Rosenman LLP is an Illinois limited liability partnership that has
elected to be governed by the Illinois Uniform Partnership Act (1997).
This document was generated from CDN thread
Created by: Alejandra Moreno on 02-09-2011 11:56:43 AM
Thanks.
Subject: RE: remote destination
Replied by: Alejandra Moreno on 04-09-2011 01:59:43 PM
I use that flag to activate/deactivate the feature without adding a TODAccess reference. However with 3 remote destinations if I enable all 3 and then disable one, make a call and disable a second destination this last one is still ringing. And it happens everytime I try. The activate/deactivate is done with AXL, I see in the admin GUI that enable mobility is not checked but the destination still rings. If I check the CUCM DB when a remote destination is added using the CUCM admin GUI the corresponding entries in tables todaccess and todaccesssetting are created. However if I create a remote destination using AXL with NO TODAccess tag there's no entry in these 2 tables. Can this be the reason?
Subject: Re: New Message from Alejandra Moreno in Administration XML (AXL) - Adminis
Replied by: Erick Wellnitz on 06-09-2011 09:21:40 AM
Have you tried deleting the entries in the TOD?  In a test environment, of course.
On Sep 4, 2011, at 1:01 PM, "Cisco Developer Community Forums" <[email protected]> wrote:
> <http://developer.cisco.com/web/axl/forums/-/message_boards/view_message/4446063>
Replied by: Alejandra Moreno on 07-09-2011 09:57:41 AM
I guess I found the problem...sometimes the refresh of the enable flag is not inmediate for the feature, that's why a destination will ring eventhough I disabled it.
