cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mark Gibson on 02-12-2009 12:52:09 AM
Hi Folks, I have a problem with one particular Key Click command. I'm trying to emulate the '*' key to point a "." into an IP address but it's not working.
Here's what I'm trying:
xCommand Key Click Key:Star
That doesn't work but all the other Key Click commands I use do.
such as:
xCommand Key Click Key:9
Does anyone know why the 'Star' one wouldn't work?
Thanks in advance for your help.
Cheers, Mark Gibson
University Of Wollongong
Subject: RE: Remote emulation problem
Replied by: David Bruun-Lie on 03-12-2009 04:47:33 PM
Hi Mark,
well - to be honest - my biggest worry is why you are using key commands in the 1st place. We really discourage the usage of key commands as there is always a direct command to do whatever you want the codec to do, e.g. to dial an IP address you'll issue
1xCommand Dial Number: "123.123.123.123"
but if you absolutely absolutely neeeeed to do it, this is a recipe:
1xcommand Key Press key: "Square"
2....wait 200ms
3xcommand Key Press key: "1"
4xcommand Key Release key: "Square"
David
