cdnadmin
Community Member
This document was generated from CDN thread
Created by: Mike Thibodeau on 03-05-2013 01:04:40 PM
I have been able to add calforwarding to a line but unable to remove it using updateLine API. CUCM v8.5
Here's a snipit of my code...
        $line = array();
        $line['uuid'] = $uuid;
        $call_forward_reset = array('forwardToVoiceMail'=>'false','destination'=>'','callingSearchSpaceName'=>'');
        $line['callForwardAll']                                 = $call_forward_reset;
        $line['callForwardBusyInt']                     = $call_forward_reset;
        $line['callForwardBusy']                        = $call_forward_reset;
        $line['callForwardNoAnswer']                    = $call_forward_reset;
        $line['callForwardNoAnswerInt']                 = $call_forward_reset;
        $line['callForwardNotRegistered']               = $call_forward_reset;
        $line['callForwardNotRegisteredInt']    = $call_forward_reset;
       try {
                $response = $cucm_client->updateLine($line);
                $return['result'] = true;
                $return['line'] = $line;
                $return['response'] = cucm_convert_obj($response,'new_object');
        } catch (SoapFault $soap_fault) {
                $return['result'] = false;
                $return['soap_faultarray'] = cucm_convert_obj($soap_fault, 'new object');
Subject: RE: remove call forwarding Via updateLine Using PHP
Replied by: Mike Thibodeau on 20-05-2013 01:15:13 PM
I have found that the API will clear one of the call forwarding entries then stop processing the call forwarding settings.  I do not find the same issue if I set the calling search space name to a valid CSS & set forward to voice mail to true.
"callForwardAll"
"callForwardBusy"
"callForwardBusyInt"
"callForwardNoAnswer"
"callForwardNoAnswerInt"
"callForwardNotRegistered"
"callForwardNotRegisteredInt"
I have not attempted to clear the no coverage, on failure, or Alternate Party settings so I don't know where in the sequence they may fall.
Is this the intended behavor of the updateLine API?
Replied by: David Staudt on 03-06-2013 06:20:02 PM
Checking the sequence below on my 8.5(1) setup:
- No forwarding configured
- Set 'Forward All', 'Forward Busy Internal', and 'Forward Busy External' via AXL
- Unset forwarding via AXL
- Check via getLine/UI
It seems to work for me, using soapUI and XML.  Please see the attached .txt file for the XML request/response sequence.
Without more details, I might postulate that PHP is attempting to set the fields to 'empty string' rather than empty  and/or null  (with regard to XML types.)  It may be helpful to look at the actual XML request/response being sent, compared to the successful sequence.  AXL request/response can be viewed using the SOAP Monitor tool, or via the AXL service logs (RTMT, may need to enable detailed AXL logging.)
