This document was generated from CDN thread
Created by: Eanna Sheehan on 11-11-2011 09:23:37 AM
I note the SetAgentState method on the Agent object accepts a SkillGroupNumber param. Can this be used to reskill the agent (ie change the skill groups they are a member of in UCCE) in a custom CTIOS desktop. I guess I'm asking about 2 different scenarios here 1) the agent reskilling themselves on their own desktop, and 2) a supervisor reskilling an agent on their team, using the supervisor desktop.
Thanks.
Eanna
Subject: RE: New Message from Eanna Sheehan in Computer Telephony Integration Object
Replied by: David Lender on 11-11-2011 11:23:06 AM
There is not a CTIOS API for agent reskilling. It must be done via ICM configuration tool or the Web Reskilling tool which manages ICM configuration.
