Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Travis May on 19-08-2011 04:30:23 AM How to increase the "rspinfo data buffer"? The as5400xm is taking 15seconds to download a 300k audio file. Seems to be using very small chunks. as5400xm is in Hong Kong, media server is in Los Angeles. Several identically configured as5400xm in Los Angeles work fine. I am seeing the following unusual http log output:
Aug 19 07:47:07.195: //280//HTTPC:/httpc_msg_read: Start processing 1608 bytes data Aug 19 07:47:07.195: //280//HTTPC:/httpc_msg_read: Stored msg. body: len=1608 Aug 19 07:47:07.199: //280//HTTPC:/httpc_msg_read: Start processing 1608 bytes data Aug 19 07:47:07.199: //280//HTTPC:/httpc_resize_datap: Response body is getting over 100 chunks, rspinfo data buffer needs resize. Aug 19 07:47:07.199: //280//HTTPC:/httpc_msg_read: Stored msg. body: len=1608 Aug 19 07:47:07.199: //280//HTTPC:/httpc_msg_read: Start processing 536 bytes data Aug 19 07:47:07.199: //280//HTTPC:/httpc_msg_read: Stored msg. body: len=536 . . . Aug 19 07:47:12.367: //280//HTTPC:/httpc_msg_read: Stored msg. body: len=2048 Aug 19 07:47:12.367: //280//HTTPC:/httpc_msg_read: Start processing 96 bytes data Aug 19 07:47:12.367: //280//HTTPC:/httpc_resize_datap: Response body is getting over 200 chunks, rspinfo data buffer needs resize. Aug 19 07:47:12.367: //280//HTTPC:/httpc_msg_read: Stored msg. body: len=96 Aug 19 07:47:12.535: //280//HTTPC:/httpc_msg_read: Start processing 1608 bytes data Aug 19 07:47:12.535: //280//HTTPC:/httpc_msg_read: Stored msg. body: len=1608 Thanks, Travis
Subject: RE: rspinfo data buffer needs resize Replied by: Anusha Kannappan on 19-08-2011 06:25:19 AM Hi Travis,
Please try configuring a higher value i.e more than 300K as per your requirement for the following command since the default value is 50K bytes only.
http client cache memory file
Thanks, Anusha
Subject: RE: rspinfo data buffer needs resize Replied by: Travis May on 19-08-2011 12:22:08 PM Hi Anusha,
Thanks for your response.
The issue is slow downloading, not caching. Caching is working fine with my existing settings:
Subject: RE: rspinfo data buffer needs resize Replied by: Anusha Kannappan on 23-08-2011 02:27:14 AM Hi Travis,
I have forwarded your query to our DE engineer. I shall get back to you when I have an answer for the same.
Thanks, Anusha
Subject: RE: rspinfo data buffer needs resize Replied by: Anusha Kannappan on 24-08-2011 02:18:36 AM Hi Travis,
Our Engineering team responded to your query saying the chunk size is controlled by HTTP server side, not on our client side. BTW which HTTP server are you using? Is it IIS or Apache?
Thanks, Anusha
Subject: RE: rspinfo data buffer needs resize Replied by: Travis May on 24-08-2011 12:22:47 PM Anusha, Thanks for getting back to me on this. We are using IIS, can you reccomend where to update this setting? Thanks, Travis
Subject: RE: rspinfo data buffer needs resize Replied by: Travis May on 24-08-2011 12:39:16 PM Here is "debug http client all": This doesn't display the error, but it does show all headers. I don't see any headers that refer to chunk size.
Aug 24 16:18:27.790: about to send data to the socket 0 : first 400 bytes of data: GET /media/accounts/xxxxxxx/186428/voiceMailGreeting_20110315110823.wav HTTP/1.1 Host: remoteMediaServer Content-Type: application/x-www-form-urlencoded Connection: Keep-Alive Accept: text/vxml, text/x-vxml, application/vxml, application/x-vxml, application/voicexml, application/x-voicexml, text/plain, text/html, audio/basic, audio/wav, multipart/form-data, application/octet-stream User-Agent: Cisco-IOS-C Aug 24 16:18:27.790: //376269//HTTPC:/httpc_socket_read: socket readable fd: 0 Aug 24 16:18:27.858: //376269//HTTPC:/httpc_socket_read: socket readable fd: 0 Aug 24 16:18:27.858: //376269//HTTPC:/httpc_socket_read: Aug 24 16:18:27.858: read data from the socket 0 : first 400 bytes of data: HTTP/1.1 200 OK Content-Length: 130360 Content-Type: audio/wav Content-Location: http://remoteMediaServer/media/accounts/xxxxxxxx/186428/voiceMailGreeting_20110315110823.wav Last-Modified: Tue, 15 Mar 2011 18:08:24 GMT Accept-Ranges: bytes ETag: "42c8b4f93be3cb1:549" Server: Microsoft-IIS/6.0 Date: Wed, 24 Aug 2011 16:18:27 GMT
RIFF0(Unprintable char...)FFFFFFFD1057415645666D7420100007010401F00401F0010806661637440000FFFFFFFD10646174 Aug 24 16:18:27.862: //376269//HTTPC:/httpc_socket_read: Aug 24 16:18:27.862: read data from the socket 0 : first 400 bytes of data: (Unprintable char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ug 24 16:18:27.866: //376269//HTTPC:/httpc_socket_read: socket readable fd: 0 Aug 24 16:18:27.866: //376269//HTTPC:/httpc_socket_read: Aug 24 16:18:27.866: read data from the socket 0 : first 400 bytes of data: 78:878<LyLJJCA>:789630(Unprintable char...)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
Subject: RE: rspinfo data buffer needs resize Replied by: Anusha Kannappan on 25-08-2011 06:10:02 AM Hi Travis,
Could you please try as mentioned in the following link for Configuring the Maximum Cache Response Size and see whether it resolves your issue
