TCC_2
Community Member
Core Issue
The cause of this problem is a bug associated with fast switched Real-Time Protocol (RTP) header compression.
The voice is still intelligible and may be described as an underwater voice.
Resolution
The issue is resolved in Cisco bug ID CSCdy57722 by a Cisco IOS  Software upgrade.
For a workaround, perform these steps:
  1. Disable the RTP header compression link.
  2. Disable fast switching on the Frame Relay connection by issuing the no ip route-cache command under the interfaces.Note: This may cause the router's CPU to increase, as it now uses the process-switched path.
To resolve the problem, use a version of Cisco IOS Software that includes the fix for Cisco bug ID CSCdy57722.
Voice Gateways
1700 Series Access Router
