cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 01-10-2004 07:57:33 PM
Can someone provide me with sample code for creating a dynamic element for Form type using Java API.
In our Voice application, we have a scenario that while playing playback prompt (the playback content is generated dynamically by a java class), the user should be able to bargein(voice & dtmf) and navigate through the menu. We are trying to create a dynamic form element for implementing the above feature.
If you could suggest any alternate or the best solution for the above feature to be implemented in our application.
Advance Thanks,
Sam
Subject: RE: Sample code for Dynamic element of Form type using Java
Replied by: Michael Bochynski on 05-10-2004 05:13:07 PM
Hi Sam,
The sample code can be found in the Developer Resources section.
Note that dynamic configuration for a Form element allows you to set not only audio prompts but also menu options, accepted DMTF input, and any other setting which is available for the given element.
You might also want to have a look at Audium documentation, especially Programmers Guide and Java API
Michael
