cdnadmin
Community Member
This document was generated from CDN thread
Created by: Janine Graves on 06-04-2007 03:21:28 AM
Can you guys PLEASE post a simple sample of how to write a logger using java?
Also, when I use documenter and look at the Properties Settings, it shows the xml for the default loggers. How does the information displayed here relate to what I might want to use in my own logger?
Also, with C/S 3.6 (CVP Vxml Server 4), can I still edit the Tomcat/webapps/CVP/WEB-INF/web.xml file to enable logging of vxml pages including the headers?
Thanks, Janine
Subject: RE: Sample code
Replied by: Vance Vagell on 06-04-2007 09:50:06 PM
Hi Janine,
In CS 3.6.x and CVP VXML Server 4.0, users no longer need to edit web.xml to enable VoiceXML debug logging. Instead, a debug logger should be configured. For instructions on how to do this on the Call Services side, please refer to the following KB article:
"How to enable VoiceXML debug mode on Audium Call Services 3.6"
Note that you can configure loggers in Studio as well, so you could follow similar steps on the Studio side (from within the project properties dialog).
In regards to a code sample for logger development, this is something we recognize would be helpful. We will keep this in mind when we update our sample code section, thanks for the feedback.
Vance
