cdnadmin
Community Member
This document was generated from CDN thread
Created by: JOHN SHEAHAN on 31-01-2010 01:22:21 PM
I'm new to CDN and thankful to be here...it took me weeks to get someone from Cisco to point me to this forum 🙂
I was hopinging that someone might be able to give me a sample piece of Ruby code (or PERL) that allows me to do something basic using AXL so I can have something to work from?
John
Subject: RE: Sample Ruby Script
Replied by: Dan-Anders Hook on 31-01-2010 02:57:04 PM
Have a look at the slide deck "Learn Administrative XML" which you can find at http://developer.cisco.com/web/axl/docs. It contains a link to some Perl samples. For your convenience I am also providing the link here: http://www.employees.org/~jkrohn/BRKUCT-2014.zip.
Kind regards,
//Dan
Replied by: JOHN SHEAHAN on 31-01-2010 07:25:01 PM
Thanks alot Dan...that REALLY helps me out alot!
take care
John
