cdnadmin
Community Member
This document was generated from CDN thread
Created by: Satheesh Kumar on 30-09-2010 07:06:30 PM
I am practiasing on CVP XVML server lab. My setup is Ingress GW---> SIP Proxy --> CVP call server --> ICM thru PG --> CVP VXML --> VXML GW. I tried working on 3 labs ( hello world, Age identification and receptionist examples posted in http://developer.cisco.com/web/cvp/download) I am using CVP deployed using comprehensive model. First two examples started to work. The third didnt work . We received 2 seconds of silent when called and hangsup. The only difference in third we are using jav API integrated to make this project work. I have deployed the project , copied the The src directory contains the Java source code for the four classes in the deploy/java/application/classes folder. -->ReceptionistEnd.class , ReceptionistGetNumber.class , ReceptionistStart.class , ReceptionistValidateNumber.java . Still i am facing the same problem if i change the script as hello world it is working.
So i would appreciate if somebody can throw light on what are the steps to be executed when java class are used to achieve a script.
Subject: Re: New Message from Satheesh Kumar in Customer Voice Portal (CVP) - Genera
Replied by: Janine Graves on 30-09-2010 07:20:47 PM
You will get more information by looking at the logs on the VxmlServer
for the error.
Look in the
C:/Cisco/CVP/VxmlServer/applications/<appname>/logs/ActivityLogs/ folder
for the most recent file. Look at the bottom and you should see which
element encountered an error.
Then look in the
C:/Cisco/CVP/VxmlServer/applications/<appname>/logs/ErrorLogs/ folder
for the most recent file. Scroll to the bottom and then slowly scroll
upward until you come to the entry with a Time/Date stamp for this call
- this should give you a paragraph explanation on what's wrong.
Perhaps you're invoking the java code incorrectly for start and end of
call (make sure you're not including the file extension, you only want
to enter ReceptionistStart or ReceptionistEnd.
Otherwise, perhaps you're invoking the ReceptionistGetNumber class
incorrectly, I believe it's a standard action.
Or perhaps you're invoking the ReceptionistValidateNumber incorrectly,
that's a decision class and you have to add the names of the appropriate
exit states into the list of exit states.
Hope that helps.
On 9/30/2010 3:06 PM, Cisco Developer Community Forums wrote:
> Satheesh Kumar has created a new message in the forum "General
> Discussion - All Versions":
> <../../../web/cvp/download>) I am using CVP deployed using
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2593719>
> or simply reply to this email.
Janine Graves
781-990-1040
