This document was generated from CDN thread
Created by: null on 13-07-2006 11:35:16 AM
I'm on a CVP 3.1 system, with Windows servers. I'm using a record-with-confirm element, but when I try to save the recorded wav file to a network share (via a mapped drive in the 'path' setting), I get the following error in the Audium logs:
An element encountered an exception of type com.audium.server.voiceElement.ElementException with the message: The path given for recording M:\en-us\sys\ITSD is not a directory.
This drive mapping is correct and I also tried the corresponding UNC path. I also tried a trailing \ on the path. If this is being caused by an NTFS permissions problem, would the error message be different? Should I set the record element path to a local directory on the Audium server, and then use some Java in the next element to copy it to the network share?
Thanks.
Eanna
Subject: RE: Saving over network with record element
Replied by: Vance Vagell on 17-07-2006 04:12:48 PM
Hi Eanna,
We recommend that you create a small Java application that attempts to save files to that same location. Then, run this test application from within the expanded CVP Server directory (e.g. the directory created from CVP.war by your application server; TOMCAT\webapps\CVP\WEB-INF\lib on Tomcat), to determine if this is a CVP-related issue or a Java-related issue.
If the Java application is able to write there, please let us know and we would be glad to continue to look into this issue.
Vance
