cdnadmin
Community Member
This document was generated from CDN thread
Created by: Daniel Scherrer on 21-01-2010 09:44:04 AM
Hi guys
I am searching a method, who can show me, which users are busy on the phone (call on..).
I have found nothing about this on the wiki-pages, developer-guides or the "Data Dictionary".
Where can i find more about this? I would tho develop a Desktop-Tool, who i can see my "Shortcuted-Users" with the status "busy" or "free", same as the Default-Display on my Cisco 7960 IP Phone.
Thanks a lot!
Dani
Subject: RE: Searching a Method
Replied by: Dan-Anders Hook on 21-01-2010 09:58:00 AM
The AXL API does not provide that kind of information. If you want line state you should use TAPI or SIP. You could also deploy a CUP and use the CUPC client 😉
Kind regards,
//Dan
Replied by: Daniel Scherrer on 21-01-2010 12:43:18 PM
Kind regards,
//Dan
Thanks a lot for your answer Dan!
That's the only way to identifier line states? I would'nt buy a CUP-Server 😞
Replied by: Dan-Anders Hook on 21-01-2010 01:06:50 PM
Yes. I know third-party systems that subscribes to presence via a SIP Trunk on the CUCM (without a CUP), although I've also heard that Cisco is not so keen on that because it (from what i've heard) has limited scalability. Other than that you´d have to use CTI.
Kind regards,
//Dan
Replied by: David Staudt on 21-01-2010 02:24:28 PM
The CTI APIs are probably what you want to look at: TAPI (C/Windows) and JTAPI (Java/multi-platform.)
UCM also supports monitoring lines via SIP/SIMPLE as well.
