cdnadmin
Community Member
This document was generated from CDN thread
Created by: Cindy Brozyno on 18-02-2012 02:02:15 PM
I created a 'time clock' app that works fine on an unsecured site (using port 80). When I moved it to a secure site (port 443), it would no longer work.
I changed all the URLs within the asp pages to https; this did nothing.
We are using CUCM System version: 7.1.5.32900-2 - will services run on https with this version?
Subject: Re: New Message from Jeffrey Ness in IP Phone Services (IPPS) - IP Phone Se
Replied by: Cindy Brozyno on 18-02-2012 09:25:18 PM
Thank you. Your answer helps more than you know. Very much appreciated
Sent from my iPod
On Feb 18, 2012, at 8:53 PM, "Cisco Developer Community Forums" <[email protected]> wrote:
> Jeffrey Ness has created a new message in the forum "IP Phone Services Questions":
> I believe HTTPS support was added (from a CUCM side) in 8.0 and higher (in CUCM there are separate HTTP and HTTPS URLs in Enterprise Parameters and IP Phone Service definitions if it is supported.) This is also dependent on IP Phone Firmware. I have implemented several HTTPS phone services in 8.5 and there are some caveats: 1) the web server public certificate (not private) needs to be added to CUCM servers on the OS side as a phone-CTL-trust. If using not using security between CUCM and phones (e.g. you have never obtained/used the security tokens and have never run the CTL wizard) this is sufficient; otherwise you need to (re)run the CTL wizard. 2) As of 9.1(1) there was a bug in using port 443 (explicitly or just as https) and just using another port works (see bug IDs CSCtj62147). Also on 8.5 there is a bug (CSCtr78976) that resets Enterprise Parameter Secure URLs upon restart.
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/ipps/forums/-/message_boards/view_message/5176695>
> or simply reply to this email.
Subject: RE: service won't work on https, ok on http
Replied by: Jeffrey Ness on 18-02-2012 08:51:20 PM
