Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 23-06-2005 01:48:48 PM Hi, I have session variable called "Prompt1". I would like to pass the value of that variable as a src to play a recorded wav file in a VoiceXML insert element. Can you show me how to do this?
Subject: RE: Session variable as a source in audio element in VXML Replied by: Vance Vagell on 23-06-2005 04:39:24 PM Hi Jaison,
You can find detailed information about how to access session data from within a VoiceXML Insert element, and much more, in the User Guide, as mentioned in my reply to your previous post.
Please refer to the section named "Voice XML Insert Elements" in the User Guide; how to use session data is discussed in the "Inputs" subsection.
