cdnadmin
Community Member
This document was generated from CDN thread
Created by: Syed Shahzad Ali on 25-10-2010 05:15:41 PM
Is there a way to automate debug trace level setting for CUCM?
I searched the following pdf but didn't find any information related to it.
http://developer.cisco.com/c/document_library/get_file?folderId=1890860&name=DLFE-25639.pdf
Subject: Re: New Message from Syed Shahzad Ali in Serviceability XML (SXML) - Servic
Replied by: Johannes Krohn on 26-10-2010 07:28:49 AM
Trace configuration is stored in table processnodeservice. You can update
the trace settings by using an appropriate "executeSQLUpdate" AXL request.
Documentation can be found in the CUCM database dictionary.
Subject: RE: Re: New Message from Syed Shahzad Ali in Serviceability XML (SXML) - Se
Replied by: Syed Shahzad Ali on 26-10-2010 03:33:37 PM
Thanks Johannes for your reply. I will let my customer know about it.
Replied by: Raghuraman Ekambaram on 20-04-2011 08:45:53 AM
Hi Johannes,
I am looking for same kind of solution to change the trace configuration using AXL.  Your reply looks very handy.  My doubt is if directly changed in the database how long it will take to reflect in the logging process.
Thanks in advance.
